Coolant leak from INTAKE???
Old Aug 11, 2006 | 08:11 PM
kainZ's Avatar
Question Coolant leak from INTAKE???
Is it possible to develop a coolant leak at the intake manifold?
Sorry for making another post, but as you can't rename posts, this is probably the only way to get real exposure to this question.
This is in refrence to the problem described here:
http://web.camaross.com/forums/showt...=1#post4031876
Old Aug 11, 2006 | 08:46 PM
Re: Coolant leak from INTAKE???
There is no coolant in the intake of an LT1. The closest it gets is the throttle body.
Old Aug 11, 2006 | 08:51 PM
Severous01's Avatar
head gasket leak could POSSIBLY end up in the intake manifold...if you're lucky and that's the only section that breaks down. very seriously doubt you'd be lucky enough to end up with a little coolant in the manifold though.
are you getting the "blue smoke" or "white smoke" coming out of the exhaust? that's a sign of oil or coolant (respectively) leaking into the combustion chambers.
Old Aug 11, 2006 | 11:19 PM
Hark_z's Avatar
most of the time coolant will splash all over everything includng the intake shen you got a bad pump
Old Aug 12, 2006 | 01:49 AM
kainZ's Avatar
its a brand new pump... and its getting on the back of the engine pass. side, not the front.
also, i have a throttle body bypass...
Old Aug 12, 2006 | 05:16 AM
luckyou03's Avatar
theres a coolant line in the rear of the passenger head.
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
