Coolant Leak, back of Motor?
Old Apr 26, 2004 | 04:08 PM
ProchargedZ's Avatar
I have coolant leaking somewhere on the back side of the motor, it is pooling ontop of the tranny and leaking down on top of the starter.
Is it possible I have a crack in the intake, or passanger head? Are there any coolant lines or plugs back there that may be damaged or broke? Any things to look for?
I just cant win with this car
Thanks for any help.
Old Apr 26, 2004 | 04:12 PM
May be the steam pipe between the heads that is visible in this pic.
Old Apr 26, 2004 | 04:28 PM
I take it, the steam pipe is the metal one that connects to both heads?
I am not sure I am that lucky, but god I hope so. Quite a bit of coolant comes out when the motor is running, but none leaks when it is off and cooled down. I also have not seen any coolant in my oil which I suppose is a good sign. I'll have to check that out... getting a look at it will be the really hard part.
Old Apr 26, 2004 | 04:38 PM
ibanez6rg's Avatar
Its a pipe the connects to both heads and runs up to the radiator on the pass. side of the intake. More than likely that is your problem.
calaban
May 18, 2020 06:43 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
blac94Z
Nov 28, 2014 01:53 PM
