Coolant leak
Old Nov 20, 2003 | 01:03 AM
NewbieWar's Avatar
Coolant leak
but the other day i was under there changing some wires and i noticed a drop of coolant on a aluminum tube. i wiped it off and continued w/ my work, but is there anything that will find the hole and plug it?
im not exactly sure where the water was coming from but... just trying to avoid over heating.
Old Nov 20, 2003 | 10:13 AM
IDOXLR8's Avatar
What aluminum tube are you referring to?
Old Nov 20, 2003 | 10:27 AM
NewbieWar's Avatar
i donno it may not have been aluminum but it looked like it, and it someplace around the opti, underneath it.
Old Nov 20, 2003 | 10:38 AM
S.J.S.'s Avatar
if its near the opti, check the weep hole on the water pump itself. The pump might be going bad and starting its drip.
Old Nov 20, 2003 | 12:02 PM
pb1995's Avatar
I just had a pump go bad that wasn't leaking out the weep hole. It was coming out the back by the drive gear dripping right on the optispark. Took me forever to find it. That was with a 2 year old GM pump too.
Old Nov 20, 2003 | 08:37 PM
NewbieWar's Avatar
how do i tell if the water pump is going south?
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
