coolant leak
Old Nov 8, 2003 | 12:39 PM
Jake300win's Avatar
coolant leak
hey i have coolant leak, the coolant is running out from the bottom pully. or that is where it is dripping down from. and also it only seems to be doing this when it is up hill. any one no where it might be coming from.
thanks
Old Nov 8, 2003 | 12:47 PM
Jake300win's Avatar
hey i just looked under the car it seems to be coming out of a small hole on the bottom of the water pump, should that hole be their it just started leaking yesterday.
Old Nov 8, 2003 | 01:02 PM
1995ta's Avatar
Sounds like your gonna need to be replacing your water pump.
Old Nov 8, 2003 | 01:30 PM
RamAir95TA's Avatar
You're going to need a new water pump.
The bearings in the waterpump are sealed against coolant so as to prevent corrosion. When the seals wear and coolant contacts the bearings, failure will soon follow. The weep hole is designed to let you know when it begins to fail.
Old Nov 8, 2003 | 02:11 PM
dkeers's Avatar
And, if you wait too long to fix it, you might kill the opti.
Old Nov 8, 2003 | 05:00 PM
94 CAMRO Z28's Avatar
Considering you have a '94, your opti is non vented. You may want to change the pump ASAP or you will be adding a couple hundred $$ to the bill because you'll also need a new opti.
Aaron
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
