coolant issues lol
Old Aug 12, 2009 | 01:08 PM
camarolover97's Avatar
coolant issues lol
Ok, This morning I was getting ready to drive to tampa to go to Busch Gardens
and i was checking all the fliuds i opened the radiator cap to see that the coolant was showing half way in the radiator i checked the over flow tank it was fine and the other day the radiator coolant level was fine can anyone tell me whats going on.
George
Old Aug 12, 2009 | 01:12 PM
Leak, head gasket, etc. You will have to do some detective work looking for leaks when the system is pressurized. Also, if the pipe from the radiator to the reservoir has a hole, the radiator will be able to push coolant toward it, but it won't return during cool down.
Old Aug 12, 2009 | 01:52 PM
ok thanks so do i just keep tapping up the radiator until i figure whats going on. alsowhile i was driving herthe other day i was smelling coolant
Old Aug 12, 2009 | 05:06 PM
Prudence would suggest you keep it as full as you can. If you smelled coolant, there is a leak somewhere. A small leak on a hose can turn into a gusher, so better get whatever it is located.
Old Aug 14, 2009 | 06:17 PM
well Today i was driving and i turned the heat on and when i got to my friends house there was coolant on the passenger floor.
is it a leak that i can have fixed and won't cost me an arm and a leg
im clueless as to whats happening should i have the system flushed out?
Old Aug 14, 2009 | 06:24 PM
OneShoe50's Avatar
Oh sounds like a heater core, might not be an arm and a leg if you take it to someone, probably just a leg.
Heater core just get tired sometimes and leak, usually inside the car like yours.
Old Aug 14, 2009 | 06:27 PM
well i have a mechanic who works on the car but do you know the process that it would take to replace the core do i even need it lol
Old Aug 14, 2009 | 08:26 PM
You would need it if you ever wanted heat. I guess you need to answer that one.
Remove hoses and clamp in the engine compartment and a couple covers under the dash, a hold down bolt or two and it's out.
Old Aug 15, 2009 | 10:09 AM
ok thanks
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
91Bird305
Sep 7, 2002 08:33 PM
91Bird305
Aug 15, 2002 07:59 PM
