Coolant indicator/sensor
Hello there, i am researching parts and prices for a low coolant sensor for my Z. I came across a " engine coolant level indicator module". Are they different names for the same part?
P.S. my problem I am trying to solve is my low coolant light being on when the system is quite full. Thanks
I agree with Shoebox! Aluminum heads don't like to be overheated; why loose a sensor that can help prevent blowing head gaskets when it is such an easy/cheap repair. Cleaning your existing sensor may work. I replaced mine several years ago and the new one is still going strong.
I have an aftermarket rad but I think the sensor is in the same spot. It is on the upper portion of the passenger side of the radiator. If you look from the passenger side past the battery, you should see a roughly 1.5" square piece plugged into the rad with an electrical connector fastened from the bottom. That is the sensor.
I found that once I removed the battery it was really easy to replace. Just used a big screwdriver to pop the old one out coming at it from the cavity created by removing the battery. Then I disconnected the connector from the old one, reconnected to the new one and then popped the new one back in.
I was lazy enough to not even drain the rad - I decided to be quick about it and let it leak while there was no sensor in there. I lost a little coolant but it wasn't too bad.
Shoebox has a good photo and write-up here: http://shbox.com/1/low_coolant2.jpg
Formula Steve
Sep 19, 2023 08:31 AM
