Need help with idle surging on DD
Old Jan 6, 2008 | 02:44 PM
LT1 FUN's Avatar
My winter car is a 96' grand prix gt with the 3.4 bone stock. On a cold day it is hard to start and left at idle it will surge between 700-1500 rpms until it warms up, then the idle is steady at 1000 in park. I thought it was the fuel regulator so i put my press. gauge on the rail and it read 44psi running. When the vacum hose is off the reg. it jumps to 52psi, could it be the EGR or throttle sensor? Motor runs good otherwise. Thanx in advance for your reply
Old Jan 6, 2008 | 03:55 PM
You might have better luck on a forum geared for that particular car. A moderator is probably going to move this post out of LT1 engine tech to the lounge.
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Double aught
Oct 2, 2015 11:29 PM
KYWes
Sep 26, 2015 08:49 AM
tdigger9899
Sep 7, 2015 10:56 AM
