Coolant flush
Coolant flush
Nothing is wrong with my cooling(ant) but i would like to do a complete flush and fill just for piece of mind..can someone point me to a step by step process of how to do a good flush and fill. thanks
Re: Coolant flush
hope this site gives you what your looking for, I was able to di it with no problems....good luck!
http://shbox.com/1/4th_gen_tech2.html#radflush
Re: Coolant flush
Go to your auto parts store and go to the section with all the fuel additives, oil additives, etc. and you should be able to spot a bottle of coolant flush of some sort. I believe you add it to the coolant and run it through you system for like 10-15 minutes and then start your flushing and filling.
Re: Coolant flush
thanks for the replies..i have gotten all my questions answered elsewhere cept for this one question..is it ok to only open the knock sensor on the block to drain and flush the block? bc i cant get to the block coolant screw on the drivers side..is just the knock sensor sufficient enough? thanks
Re: Coolant flush
Re: Coolant flush
You should remove both the knock sensor and the drain plug on the driver's side...coolant will come out of both. The motor mount bolt may be in the way of the driver's side drain bolt...you can remove the motor mount bolt to get to it.
Re: Coolant flush
thanks shoebox..i am following your write up as well as running a flush through the system prior..i am going to take off the thermo and flush the block with a hose so if i do this will it get everything even if the block coolant screw is not opened?
Re: Coolant flush
Re: Coolant flush
ok here is what i plan on doing..i dont want to (and am not) open either plug on the block but want to flush the block as well..tell me if this is ok..
1. empty radiator via petcock pour in 2 bottles of prestone flush and fill rest of radiator with water. Run engine round town for 10 min at oper. temp
2. let cool and drain petcock again. take off thermo and reattach housing. run a hose into the radiator cap with engine running and petcock open untill petcock shoots straight water.
3. turn off engine and let petcock drain..reattach thermo..so now the block is filled with just tap water from my hose and the radiator is empty...fill radiator with dexcool..start engine and they will mix
do you think the amount of water that is filled in the block is equal to the amount of dexcool the radiator will be filled with? will it be around a 50/50 mixture? does all this sound ok?
Re: Coolant flush
can i get all the green coolant out of the entire system by having the thermo out and running a hose in the radiator cap while having only the radiator petcock open and the engine running with the intake and MAF disconnected?...then coouldnt i just take away the hose and run the car until virtually all liquid is gone(watching the temp of course)?
