coolant dripping on the passanger side floor
Old Oct 17, 2003 | 01:17 PM
rage366's Avatar
i've been using my heater the last few days and today, i noticed a big puddle of coolant on the passanger side floor...it appears to be dripping from under the back of the glove box....help please.
Old Oct 17, 2003 | 01:18 PM
IXLR894Z28's Avatar
I do believe your heater core may be shot, or one of the hose fittings at the core, they are both located right there.
Old Oct 17, 2003 | 01:19 PM
LT1TONY's Avatar
Just wondering is your windshield fogging up as well.
Sounds like it might be heater core related if it's on the inside passenger floor.
Old Oct 17, 2003 | 01:33 PM
grygst76's Avatar
bye bye heater core, replace it.
rage366's Avatar
YES!! YES!!! YES!!!!!!!!!!!! you got it RIGHT ON THE HEAD!! damnit! i noticed my winshield fogging up today, and i've never seen that before...i thought it was odd.
how much do those things cost anyway?
edit: oh yeah, will it stop leaking if i dont use the heater? or will it leak until i replace/fix it?
Old Oct 17, 2003 | 01:38 PM
grygst76's Avatar
It gets worse, replace it, factory heater is around 100.00 or more I'm pretty sure, but go to a junkyard and look for 93 and up camaro with low miles and rip one out of it. they'll sell it to you for around 10.00
Old Oct 17, 2003 | 01:40 PM
LT1TONY's Avatar
Not really too sure on how much the newer ones like this go for. I'd call your local auto parts store and see if they have it in stock and ask how much. I know the ones for older GM cars are about $35-$50 bucks. Not sure as to how hard it's to remove too.
I know a lot of other guys on the board here have removed them for weight, so hopefully some one can give you an idea there.
Old Oct 17, 2003 | 01:43 PM
LT1TONY's Avatar
If your going through all that trouble, I really would put a new one and forget about an old one. You don't want to have to tear it out again.
It does get worse and will fog up even more.
Old Oct 17, 2003 | 01:46 PM
grygst76's Avatar
It'll take him about 20 minutes, after ripping it out of the junk one in the junkyard, he will know exactly how it comes out/goes back in. It takes longer to drain the coolant. Old I meant meaning low miles like less then 40,000. they go bad in our cars usually 80,000 and up
Old Oct 17, 2003 | 01:48 PM
rage366's Avatar
weight, eh? hmmm *scratches chin,* so, how difficult is it to BYPASS the heater core then? HOW do you bypass it?
any detrimental effects to the motor?
Old Oct 17, 2003 | 01:56 PM
grygst76's Avatar
bypassing the heater is not recommended IMO it will run hotter due to less coolant being in the system just replace it would be a good option.
Old Oct 17, 2003 | 02:21 PM
NVetro's Avatar
Definitly the heater core
Old Oct 18, 2003 | 12:24 PM
rage366's Avatar
ok, uhm, any hinters on how to EASILY change out the heater core? is there a good way other than takin out the friggin dash?
Old Oct 20, 2003 | 04:37 AM
grygst76's Avatar
you only have to move the glove box per say just press it together at the ends, you'll see what I mean, it looks harder then it really is.
Old Oct 20, 2003 | 05:13 AM
jasycZ28's Avatar
A new heater core from Autozone was under $50 I can't remember exactly how much I paid. It took under and hour to swap in the new one. Just pull out the glove box and take off the black cover. And disconect the two lines in the engine bay. The hardest part is getting those clips back one.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
mattstrike
Mar 11, 2015 07:33 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
dale3in98
Feb 14, 2015 12:18 PM
wildchild
Sep 9, 2002 11:47 AM
