coolant crossover tube
Old Jun 25, 2003 | 10:10 AM
MY91Y84's Avatar
could you guys read my thread and help m eout on this?...i been tryin get some help over there for a couple weeks and noone will
thanks guys!!
Rob
http://lt1tech.com/cgi-bin/ultimateb...c;f=6;t=000966
Old Jun 25, 2003 | 10:22 AM
thewinner's Avatar
guy at the dealer has no clue wtf he is talking about IMO.
the tube is not gonna mess with clearances expecially in a 3rd gen. in the fbody the banjo bolts are almsot right against the firewall, so i cant see any probs in a 3rd gen.
Old Jun 25, 2003 | 10:27 AM
MY91Y84's Avatar
well damn dude..thats one "issue" taken care of....i didnt think there would be any clearence issue. but the GM parts guys know it all...any idea on the 2 holes on the side of the head?
it was about 2 days before i got a reply over there, you replied in like 2 mins!...
thanks alot man!
Rob
Old Jun 25, 2003 | 01:47 PM
Mtrhds94Z's Avatar
The holes in the sides of the heads are for a coolant sensor[one, on drivers side, for the temp guage..
The front hole [and the 2 side holes] are due to the heads being reversable.. you can plug the front and one side hole..
The coolant steam pipe can't just be plugged off, or you may as well just plug the rear holes?
It has to tie into the cooling system..
Do you have an LT1 radiator?
It'll have provision for that hose [skip the throttle body and run it as a 'TB bypass' setup, direct to radiator..]
Heres' the cooling hose diagrams compliments of shoebox' site:
http://csce.uark.edu/~jgbertr/rb/95-97_hoses.jpg
http://csce.uark.edu/~jgbertr/rb/heater_hoses.jpg
I am suggesting the 95-7 hose configuration here as opposed to the 93-4.. you can get the Goodyear hi miler kit for it for about 100 from Summit etc..
Old Jun 25, 2003 | 02:04 PM
MY91Y84's Avatar
i dont have an LT1 radiator..im using all my 3rd gen stuff in this..
this is also a carbed setup..
ok how about this..my car has an oil cooler..i connect the tube and it runs toward the TB..well my oil cooler lines are pretty close, so what about running the tube into my oil cooler lines..which go directly to the radiator... im sure i could rig something up
since my ECM will no longer be performing any function how will i get the temp guage to work?
Thanks!!
Rob
Old Jun 26, 2003 | 05:21 PM
MY91Y84's Avatar
i need some input on this guys!
Old Jun 27, 2003 | 12:29 PM
MY91Y84's Avatar
TTT
Old Jun 27, 2003 | 11:28 PM
MY91Y84's Avatar
tomorrow im gonna finish it up and i would really like to knoe if i can tie in the coolant tube into my oil cooler lines
i can get it to work i just need to know if it will
about also about the coolant temp sensor..
my car doesnt have an ECM anymore so would there be a point to putting it in there?....if theres a way to make it work then great!..but ill have my dual electric fans on all the time so i wont really be worried about the engine temp...to a point that is
Old Jun 28, 2003 | 11:28 AM
Mtrhds94Z's Avatar
aThe PCM temp sensor is in the water pump housing..
The temp guage sensor is in the drivers side head..
Why not get an aftermarket guage with sensor and put it in there?
Look on shoebox page for those hose diagrams... on the 93-4 configuration there's a 'tee' in the bleeder pipe, as opposed to a plain pipe in the bleeder for 95-7...
That might be a good place to connect the steam pipe [since you aren't using an LT1 radiator with the proper fitting]
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
cmsmith
Jul 2, 2015 10:26 PM
cmsmith
Mar 16, 2015 02:34 PM
JurisAg02
Jul 27, 2002 11:49 AM
