coolant bypass is it needed?
Old Nov 30, 2003 | 09:08 PM
squinn's Avatar
If not running a thermostat do you need to run the coolant bypass hose on and lt1 motor. That would be the lower hose on the driver side of that radiator. Just trying to drop any weight I can off the car.
Old Nov 30, 2003 | 09:17 PM
Zerosheaven's Avatar
no idea..but i think you realy should be runnin a thermo, atleast a 160 one. i think the car would actualy overheat without one doesnt it?
Old Nov 30, 2003 | 09:18 PM
tanker's Avatar
I don't know about dropping weight, its just a hose , but performance wise it's proven to add some hp.
Old Nov 30, 2003 | 09:41 PM
I assume you mean the bypass hose that runs from the LH side of the radiator to the water pump. I don't belive it is necessary. Pretty sure the B-body LT1 does not use it (maybe Corvette, too).
I would recommend you use a thermostat, though. Because of the design of the LT1 pump, coolant flow will be less efficient without a thermostat.
Old Nov 30, 2003 | 09:47 PM
squinn's Avatar
This ia a race car not at street car, at this point every oz. counts
Old Nov 30, 2003 | 11:19 PM
DrivinSidewayz's Avatar
do you take a **** before you race???
lol sorry i had to
Old Nov 30, 2003 | 11:28 PM
S.J.S.'s Avatar
9.90's...... damn bro, whatcha got in there???? NA you say?
Old Dec 1, 2003 | 08:52 AM
mongse_1's Avatar
Damn Steve, you're crazier than me about weight.
Old Dec 1, 2003 | 08:57 AM
Brady's Avatar
you don't have to use that hose, I plugged mine off and it was fine. I did it for better cooling, but I guess it was worth a few ounces too
Old Dec 1, 2003 | 09:35 AM
squinn's Avatar
Thanks Brady thats what I needed to know.
S.J.S. gm lt1 head, solid roller, 370 CID, 3225 lbs
Old Dec 1, 2003 | 10:46 AM
Camaro_Guru16NY's Avatar
Some people say it works while others say it doesent. You might as well give it a shot.
Later,
-JOhn
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
mjcent922
Jul 27, 2002 12:42 PM
