coolant boils over everytime i park
Old Aug 5, 2008 | 10:13 PM
jlmeraz's Avatar
good evening everyone,
i have a 97 z28 and everytime i drive it for more than 20 minutes then park the coolant/water comes out of the coolant boilover tank, i keep filling it up with water, but after driving it 3-4 times i need to fill it up again. it doesnt over heat, the worst that will happen is my "low coolant level" sensor turns on and i just fill it up again also when the coolant gets to low, but not low enough to trigger the sensor, the engine temp goes up 3/4 of the way before the thermostat kicks in and cools it down.. anyways, where should i start?
Old Aug 5, 2008 | 10:19 PM
camarozz95's Avatar
Could be your thermostat is stuck closed or your radiator cap is bad.
Old Aug 5, 2008 | 10:29 PM
jlmeraz's Avatar
thermostat was changed recently.. can the rad. cap impact the system that way?
Old Aug 5, 2008 | 10:33 PM
camarozz95's Avatar
yeah pretty sure take a look at this thread: https://www.camaroz28.com/forums/sho...d+radiator+cap
Old Aug 5, 2008 | 10:56 PM
If the cap is not holding pressure, it's going to blow by into the remote reservoir.
Old Aug 5, 2008 | 11:41 PM
jlmeraz's Avatar
how funny.. such a simple fix. I took the old cap off after driving it and NO pressure was released! thank god it wasnt something expensive.. thanks for all of the quick replies
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
maverickmk
Sep 1, 2015 09:17 PM
