coolant in AIR?
Old Apr 22, 2004 | 01:29 PM
Eff's Avatar
Eff
coolant in AIR?
I was replacing my elbo with a 1-LE elbo because occasionaly the car would buck like it was going to die and go in to speed density mode. I tried replacing the MAF. wasn't htat. so I though a small rip in the seem of the elbo might be causing an air leak.Well, when I pulled it off and dropped the silencer it dripped fresh coolant out of it. Following the trail, it lead back to the air pump hose after the air box. There is no doubt in my mind that this was the problem. Just can't figure out why it's there.
Old Apr 22, 2004 | 02:37 PM
LWillmann's Avatar
Considering the air pump is a selfcontained unit, there's no logical reason for it to be coming from there.
Old Apr 22, 2004 | 03:45 PM
curly's Avatar
Could it be condensation that you're seeing? That is one thing that has "killed" many AIR pumps on these cars from what I have read. Air coming in.... condenses.... kills electrical components. Two AIR pumps later, I have taken care ofd that problem .
Old Apr 23, 2004 | 11:23 AM
Eff's Avatar
Eff
I looks like anti-freeze was directly spilled in to the pump.
This guy I bought the car off of, claims he's a mechanic, but he sure did a lot of really weird things.
Old Apr 23, 2004 | 02:22 PM
Coolant and AIR pump should never meet. Bizarre.
Old Apr 24, 2004 | 12:14 AM
RENE95Z's Avatar
My car threw a code and it was the AIR pump. When my friend and I removed it and took it apart, voila; something that looked like coolant in the pump. How? No clue. Why? No clue. Ditched the pump and put in a good fuse and forget about it? You got it.
Old Apr 24, 2004 | 02:03 AM
scoobysnax83's Avatar
blame it on the gremlins....
Old Apr 24, 2004 | 09:33 AM
TonyJ's Avatar
This problem was fixed by a recall. It was a free dealer upgrade of the AIR pump and associated plumbing. Takes a half day and was free back when it was issued. Don't know if you'd still qualify.
http://web.camaross.com/forums/showt...ght=air+recall
Old Apr 26, 2004 | 08:58 AM
Eff's Avatar
Eff
Hmmm... sounds like my problem. But I have a 94. I suppose I could just delete it.
calaban
May 18, 2020 06:43 PM
Fatdog2
Apr 27, 2015 10:32 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
MattFick
Feb 15, 2015 10:16 PM
95chwagon
Jan 13, 2015 09:19 PM
