coolant
Old Apr 12, 2003 | 04:56 PM
Kearn's Avatar
coolant
i overfilled the radiator by a lot and even the overfill reservoir is overfilled. how do i drain some of the coolant out? thanks for your help.
Old Apr 12, 2003 | 04:58 PM
jasons93z's Avatar
you could open a bleeder screw
Old Apr 12, 2003 | 07:26 PM
Mtrhds94Z's Avatar
Or the radiator drain?
Old Apr 12, 2003 | 10:56 PM
Kearn's Avatar
i know where the radiator drain is, i just reinstalled the water pump and when i was filling the radiator up, i over filled the radiator along with the coolant/overfill reservor. so my question is how do i undrain or take out some of the liquid in the overfill reservor (left of the batter when facing toward the car).
thanks for any help
Old Apr 12, 2003 | 11:05 PM
norcalstreet's Avatar
Unscrew the radiator drain and let some of the fluid drain out. You could do nothing and just let it overflow. It's far enough away from the optispark that it shouldn't cause a problem.
Old Apr 13, 2003 | 11:26 AM
Mtrhds94Z's Avatar
From shoebox' site:
http://csce.uark.edu/~jgbertr/rb/95-97_hoses.jpg
Remove hose #27 from the radiator end..
Put in container, etc...it should drain some out..
[You might blow into the fill tube to 'pressurize' it..]
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
