Cool, keeping her cool, sugestions.
Old May 26, 2005 | 01:35 AM
NewbieWar's Avatar
Well I have a 160 thermostat,
but she still soars up to the red without me moving...
I will be doing some cooling work like replacing water pump (probably go with electric) replacing all the hoses, replace heater core and hook it up
but how will i know at that point whether or not she is gonna stay below 190?
I've been on the side of the road overheated more times then i can count and I only drove the car for 14 months... and put about 20k miles on her.
so any suggestions would be enjoyed
Old May 26, 2005 | 01:57 AM
phinger23's Avatar
Re: Cool, keeping her cool, sugestions.
did you bleed the system?
Old May 26, 2005 | 02:00 AM
1996camarors's Avatar
Post Re: Cool, keeping her cool, sugestions.
( looks into crystal ball) (I see a good coolant flush in your near future)
Flush-it-fill-it-forget-it.
Old May 26, 2005 | 02:03 AM
phinger23's Avatar
oh, and....
coolant level? is it good? any leaks? is the thermostat any good? is it even working?
Old May 26, 2005 | 02:05 AM
^ is your stat for a reverse flow system?? if not then its not opening
Old May 26, 2005 | 03:48 AM
fredmr39's Avatar
Make sure the level is good and air is bled - check these daily until it is flushed when you have time (hopefully over the weekend at the latest). I'm needing to flush mine as well > : - >
Old May 26, 2005 | 10:30 AM
NewbieWar's Avatar
well i dont accually drive the car any more... just once a week i take her around the block...
im pretty sure she leaks some where but i cant find out where... perhaps it burns off...
I've flushed her lots of times...the stat is the hypertech 160 for reverse cooling
ever since i put the stat in while im moving the car is cooler...
does anyone know if the heater core isnt hooked up if it runs hot?
and possibly the guy before me might have routed everything wrong?
Old May 26, 2005 | 11:28 AM
BUBBA's Avatar
fans?
Old May 26, 2005 | 11:42 AM
Z28SORR's Avatar
The 160* thermo. only helps when you are moving unless you have the fans set to come on earlier. Or you can install a manual fan switch.
In any case the fans should still come on, around 220*, before it over heats (gets to the redline).
So I would be checking the fans for proper operation.
Old May 26, 2005 | 07:31 PM
DiabloGT's Avatar
i havent started up my car since i put a 160 stat, but i wont start it up till like 3 weeks when i get headers, do i really HAVE to bleed the system or only if it has a problem?
thanks
Old May 26, 2005 | 08:32 PM
thanks
Uh ya you need to bleed it because the air in the system create pockets and hotspots on the cylinder wall
Zuvell
May 15, 2015 08:18 PM
May 1, 2015 01:14 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
