converting to a NSA rocker
Old Jan 3, 2007 | 10:59 AM
Zeetwentyfate's Avatar
Hey guys what the best parts to convert to a NSA setup....i wanna know a good hardened pushrod, a good cheaper narrow body roller 1.6 rocker, and what guideplates....and do i HAVE to use narrow body rockers or not?
Old Jan 3, 2007 | 11:15 AM
mdacton's Avatar
I used regular rockers,comp guide plates, comp rods
I have a cheap set of pushrods in the sale forum comp 7808....They are inexpensive hardened pushrods
Old Jan 3, 2007 | 11:16 AM
CustomSSI's Avatar
You don't have to use narrow body rockers... But if you don't you will have to modify your valve covers a bit.. We'd recomend the comp pro-mags, comp pushrods and GM guideplates. Might as well upgrade to 7/16" rocker studs while your at it to since you'll be buying new rockers also... What is your budget for this?
Old Jan 3, 2007 | 09:06 PM
i have like 250 to spend ...i dont need top quality on a motor that has 132k miles lol but i dont want junk either. what part # would you recomend for the guidelates?
Old Jan 3, 2007 | 09:19 PM
mdacton's Avatar
look in the sale section I have a set of crane gold self aligns if your interested
I always use comp guide plates, didn't know gm made them but whatever floats your boat
Old Jan 3, 2007 | 09:33 PM
The GM guideplates (14011051) have the correct spacing. The Comps may not if they are the same ones used on the SBCs.
2QUIK6
Jul 15, 2015 07:46 PM
timmy39120
May 2, 2015 05:12 PM
alliance12364
Mar 6, 2015 04:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
