Converting from 4L60E to 700R4 info?
Old Jul 18, 2005 | 09:09 AM
zmanlt1's Avatar
Arrow Converting from 4L60E to 700R4 info?
I posted this in the drivetrain forum. Let me know if you guys have anymore info for me. Thanks Tom
Link to my post in the drivetrain forum
Old Jul 18, 2005 | 09:18 AM
'94 Bad A Z28's Avatar
Re: Converting from 4L60E to 700R4 info?
Why are you going to a 700R4?
Old Jul 18, 2005 | 09:36 AM
zmanlt1's Avatar
I want to get rid of the electronic transmission and not to mention the internals that this 700R4 has. This 700R4 is rated to handle the amount of power I plan on running in the near future. It would have cost me too much to do all of this to the 4L60E. The 700R4 has never been run in a car and also came with a pistol grip Hurst shifter and a TCI converter for just about $1200. The person who had it built by Ziggy's high perf. transmissions put around $2000 into this tranny.
Old Jul 18, 2005 | 09:49 AM
sssalah's Avatar
A friend of mine is running one in his 97 Z. Should work fine, but it'll throw a code for no VSS signal and the ABS might not work.
Old Aug 25, 2006 | 04:08 PM
1BadBrd's Avatar
i was curious what it would take. A friend builds 700r4 all day and claims he can build a 700hp trans from a 700r4.
Although he keeps telling me if i want auto to go for a 4l80e tranny
Old Aug 25, 2006 | 06:05 PM
1racerdude's Avatar
Should be pretty much a bolt in except for the computer problems the MadZ28 can fix.
Old Aug 25, 2006 | 06:10 PM
96capricemgr's Avatar
Any good 700R4 build is going to use a lot of the updated internals from the 4L60E, think about that for a second.
The hardparts are interchangable with the 4L60E getting the more up to date and stonger pieces. The 4L60E gets blamed as weak but the truth is most builders just aren't capable of building it well.
Old Aug 25, 2006 | 09:34 PM
ShowStopper540's Avatar
The 700R4 and the 4L60E are the saaaaame daaaaamn transmission inside, same gear ratios and all, the only difference is one is operated by a TV/Kickdown Cable (700R4) and the other is electronically controlled (4L60E). To be converting would in my mind be a waste of your efforts, id just go with a built 4L60E.
thenewkid
Apr 12, 2015 07:42 PM
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Dec 28, 2014 09:30 AM
Victory Racing
Sep 1, 2002 05:34 PM
veryslowfbody
Aug 22, 2002 04:31 PM
