Converter guys inside please!
Old Feb 10, 2003 | 07:02 PM
2slow4u's Avatar
I was needing to know what shift points you were using with your converter? I have the Hypertech programmer and was wondering what you had the rev limit set to and also where you tell the car to shift. I am gonna be installing a 2800 stall on a 94 z28 tommorow and I will need to know then. This is a stock internal, bolt on car with no power adder by the way.
Old Feb 10, 2003 | 08:12 PM
jcolez28's Avatar
Ive never heard of raising shift RPMs for a converter. I raised mine to 6000-6100 for a cam and RRs. Your stock valve train may not like high RPMs. You may break a rocker or push rod.
Old Feb 10, 2003 | 08:18 PM
BlkScreaminMach's Avatar
Question Me neither
I have with my cam like a 6200 rpm rev limit, i neevr used HPP3, but my buddy did. He just messed with it until he got proper shift points, but that had to deal with a 3.23 gear to a 3.73 gear swap, and he was fine after he messed with it.
If yours is a locked up style converter just foot break and stall just short of the tires spinning, lauch it and if it seems your shifting too early, adjust accordingly.
ChrisFrez
Feb 15, 2015 07:49 AM
joe777107
Dec 1, 2014 09:32 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
