Confusing p1371 code.
Old Sep 20, 2021 | 08:30 PM
  #16
theformula97's Avatar
Re: Confusing p1371 code.
Originally Posted by Injuneer
The Opti will not affect the voltage of the pulse on the white wire. That pulse is developed and sent by the PCM. The pulse is a short 5 volt square wave. It's not just passing through the pulse produced by the Opti.
Not sure which one is the white wire because my ICM harness has been replaced and they're all different colors than OEM. Pins A and D checked out fine at 11.8 DC volts. Pin C read 0.0 ohms. Pin B was the only parameter that was off. I thought the pulse that the PCM sent was based off of the High and Low res signals that the optical sensor sent out?
Old Sep 21, 2021 | 01:03 AM
  #17
Pin B is the white wire (circuit 423). From PCM connector C2 pin 5:
http://shbox.com/1/1996_ec_03_ign_system.jpg
The PCM needs to know which cylinder is approaching TDC. It knows this based in the width (duration) of the low resolution pulse from the Opti. It knows the width of the low res pulse by counting the number of 1° high res pulses between the leading edge of the low res pulse to the trailing edge of the low res pulse. Four of the cylinders have a unique variable width pulse ranging from 7° to 22° wide. These four variable width pulses alternate with four equal 2° width pulses for the other cylinders.
Then, the PCM uses the timing tables (RPM on one axis, MAP on the other axis) to determine how many degrees in advance of TDC the spark (or the injector pulse) should occur. At exactly the right time the PCM sends a 5 volt pulse to the ICM to fire the correct plug, based on the position of the Opti rotor. The PCM is not simply picking a pulse out of the Opti's low res or high res stream, and forwarding it to the ICM. The PCM sends it own pulse to the ICM, and opens the injector with its own ground pulse. The source is a 5-volt regulated power supply in the PCM.
I use only the optical sensor in an OEM vented Opti to feed the cam/pseudo-crank position data to a MoTeC M48Pro engine management system, with an IEX 8-channel ignition module, driving 8 LS1 coils in direct fire. Works the same way. The MoTeC adds additional options on injector timing, allowing the injector pulse to be based on the leading edge of the Opti low res pulse, or the trailing edge of the low res pulse, and can calculate the start of the injector pulse by using “start of event” calculation, or back-calculating using an “end of event” basis. This helps coordinate the injection pulse width with the intake valve opening to prevent fuel from impinging on a closed valve, when possible. It's complicated.
Old Sep 21, 2021 | 02:37 AM
  #18
chevykid's Avatar
Originally Posted by theformula97
Saw this a couple days ago. My opti is aftermarket(Spectra) so would he be able to rebuild it even though it doesn't have the Mitsu sensor? And if so would this be a better alternative to buying a Summit Opti? Because it seems like those are my only two options at this point.
i would message him and see what he says
Old Sep 21, 2021 | 11:53 AM
  #19
Yeah it seems complicated. I understand that the Opti does not send the 5 volt pulse straight to the ICM and I know now that the pulse is developed and sent by the PCM, but I thought that the pulse the PCM sent out was based on what the opti was telling it as far as High and Low res signals? If not, would it be worth my time to trace the white wire from the ICM back to the PCM to see why I am getting low voltage? Or could it be something internal with the PCM or some other problem?
  #20
Okay thanks.
Old Sep 21, 2021 | 12:50 PM
  #21
I'll try this one more time.
The PCM uses the “timing” of the Opti pulses. The voltage of the signal from the Opti, or even the exact shape of the “square wave” pulse is not important, as long as there is a clearly defined beginning and end to the pulse. You aren't going to get a weak (low voltage) pulse sent from the PCM to the ICM because the pulse from the Opti to the PCM is “weak”, or because a pulse was missing from the Opti signal.
Why did you not get at least 1.0 volts on the white wire? Could be:
- corroded or damaged white wire, or connector pins
- poor ground at the ICM
- faulty voltage from the PCM regulated source
- short in the ICM
- meter or user error
Probably other possibilities, but that's all I can think of for now.
Try using the DC voltage scale on the meter. That is what the factory service manual instructions indicate for P1361- IC Voltage Low. Might want to look up that code in the manual for additional help. The digital volt meter specified in the FSM apparently has the ability to recorded the high and low DC voltage encountered during the test.
Old Sep 21, 2021 | 01:04 PM
  #22
- short in the ICM
Okay I understand now. So there should always be at least 1 volt sent via the white wire regardless of what the Opti is telling the PCM. I have had a P1361 before and got it fixed by cleaning all the grounds at the driver side head and replacing the cheap ICM. I had removed the ICM/Coil assembly and put it back on to test the white wire. I will try to get back to it and make sure the grounds are good and tight and test it again.
Old Sep 21, 2021 | 02:26 PM
  #23
- short in the ICM
Just tested it again. Got all the grounds for the ICM bracket clean and tight and made sure the ground for my test lead was clean. I cut the white wire a little ways down from the ICM connector and stripped it to expose the copper. Got the same amount of voltage. The only thing I can think of to do now is test the white wire towards the PCM to test the possibility of a frayed white wire somewhere between the connector and the PCM. Very lost and getting tired of dealing with it.
Old Sep 21, 2021 | 07:26 PM
  #24
Did you need to cut skin the white wire because the connector was still on the ICM? But you cut the white so it was no longer connected to the connector? Was this to see if the voltage loss was in the connector? Were all your tests done with the connector off the ICM?
Old Sep 21, 2021 | 07:31 PM
  #25
Sorry if my response was confusing. I cut the white wire on the ICM connector a few inches from Pin B and tested just the exposed wire, not on the connector itself. This was to eliminate the possibility of a corroded pin or something inside the connector. Yes the ICM connector testing has been done with the ICM unplugged but with the coil connected.. I have been following the Shoebox guide for most of the testing.
GLICKGLOCKMEX
Dec 20, 2007 06:33 AM
Coasterkid
Dec 9, 2007 04:48 PM
money pit
Jun 5, 2006 07:32 PM
ramermanz28
12
Dec 19, 2004 11:11 PM
Rich_z28
Mar 29, 2003 12:45 AM
