Computer wont run tests...
started my engine up saturday.
357 with a mad z28 mail order tune. i had madz28 delete my air pump, air conditioner, and egr. i only have 40 miles on the car, but it hasn't run my catalysts test, or my egr tests. my dad's got a gm scanner i can check my emission codes and they aren't "not ready" the tests just haven't actually been ran yet.
i know the computer needs certain conditions to run the tests, but i've let it idle, accelerated, decelerated, and ran it on the highway. what could the problem be? need to take the car down to emissions and i need all these tests ran.
thanks
-Jason
thanks
-Jason
Re: Computer wont run tests...
oh ok cool. just wondering, wanted to know what i needed to do. my dad is freakin out and was gong to make me go buy a thermostat cuz my "160 won't let the car get hot enough"
The car will not pass the scan test if those emission devices were deleted. You need to have the actual parts on the car (except for rear o2s - you can use sims) and the tests enabled to pass. You are allowed 2 fails however, so you can do this:
Send the computer back to enable all codes besides EGR or AIR (if you want to take advantage of the 2 fails allowed). I doubt you have a problem with your carbon canister purge system which you asked to disable. You can run o2 sims for the rear o2s and you should pass that way.
as of right now, out of the 5 or 6 codes it needs to run for emissions, only 2 have actually been tested, and both are "ready" or passed.
my question is, will the other 3 tests, egr etc.,
either not test--OR-- test and fail?
if they run and fail its fine as long as only 2 fail..but i'm under the impression that if 1 doesn't test at all, it won't pass.
Yes, I have your tune on file.
I'm sure we can make it pass as long as you send me the list of the codes it actually fails and also let me know if you still have EGR or AIR on the car, but either way, you should be getting two fails right now for the cats, one for EGR, one for AIR and possibly one for Carbon Canister. We can fix the two for cats and the one for CCP, so you will be left with two and you should pass without any problems. Others have passed the same way before.
thats the thing i need to know.
i'm not failing those codes, because the tests haven't been ran yet. i need to know if the computer will still eventually run the tests. after you clear codes it takes a certain number of miles or key cycles before it will run tests again. if they test, then fail, i'll have to have it fixed. but will all of the codes including air/egr test?
I just don't want to drive the car around for another week, and find out the test won't even run. pass or fail doesn't matter, not even run.
The fact that you're driving it right now, won't change anything for those that have been disabled. They need to be re-enabled in the PCM through reprogramming. Like I already said though, I know a few people who passed with the two codes disabled so yours should pass too.
alright, thanks for the help..maybe i'll take it down there tomorrow afternoon and see if it passes. ses light is not on . but only 2 out of the 5/6 codes have been ran so far, and both have passed. but 4 are still unran.
just so ya know, the car runs good, the tune u gave me has been working out well..it is holding a nice idle. thanks
-Jason
-Jason
put the scanner back on last night, this is what i got.
test completed
catalysts NO
O2 sensor? YES
air YES
HO2S ?? NO
egr NO
my dad said the other tests might not be running cuz the car isn't getting up to operating temberature. have a 160 stat..going to put a stock 190 or whatever in it today and see it it will run the other tests. found out if i DO take the car for emissions, and it fail the first time, i can't pass unless i show paid reciepts that shows i tried to fix it, totalling a minimum of 450$ !!
test completed
catalysts NO
O2 sensor? YES
air YES
HO2S ?? NO
egr NO
The guy who programmed your PCM is telling you:
Just because you have a 160deg t'stat doesn't mean the coolant is running at 160deg. What temp is it running at? Anything over 140degF is enough to put it into closed loop.
Generally on the emissions failure (not sure how MO compares to other states), ONLY IF IT FAILS MULTIPLE TIMES are you required to demonstrate that you spent the $450 TRYING to fix it, and couldn't fix it. They give you a provisional sticker. I can't believe they would require you to spend $450 to fix it, no matter what it failed for. If you had a bad $3 spark plug, it wouldn't make any sense to require $450 worth of work. I think you have the requirements confused.
well i still havn't gotton the main question answered..
will the tests RUN ? -not will they pass- will they RUN ?
if they run and fail it will throw an ses code right?
or an i wrong about that.
IF: they will throw an ses code if they fail, they haven't even ran yet cuz my light isn't on.
sorry for being a pain, but for some reason i'm not 100% understanding this. just don't wanna get [edit] on my emissions...just wanna get a pass sticker
if i would send my computer back to get retuned to pass emissions, i'm guessing i would have to put the egr and air pump back on? [edit] !!
Let me start by telling you (moderator hat on) that you shouldn't override the language filter. PLEASE don't do that again.
The scanner is doing a "system readiness" test. It won't find the systems "ready" because they aren't turned on in the PCM. When you turn the systems on, you will get an SES light, unless he can set the system activation parameters outside the limits the engine will see during the emissions test.
I'll let "madwolf" correct any errors I made in the above.... but I think that's the message you aren't understanding. When you delete systems that have no negative affect on the performance of your engine, this is the trouble you get into.
well i guess only thing i can do is take her and get it tested. . i'll let ya know madwolf if i need some "fine tweeking"
thanks for the help
-Jason
oh sorry bout that, didn't even know there was a language filter on the site, was making my own filter.
thanks for the help
-Jason
