computer/wireing harness messing up possibly?
Old Feb 27, 2006 | 10:56 PM
96ZCamaro's Avatar
Exclamation computer/wireing harness messing up possibly?
Ok, well I tryed to route my fan switch through the firewall today. Took the computer out and all that whatnot, could not get it through. But anyways, once I put everything back together, when I first start the car it seems as if it has no power at all, and backfired once. Checked the connections and everything again. But for some reason still wanting have no power for first couple min. or so on start up. But runs just perfect after a while....I am clueless on to what I messed up now . Need help!! Any opinions appreciated even if your not sure what it might be.
Old Feb 27, 2006 | 11:27 PM
96ZCamaro's Avatar
Re: computer/wireing harness messing up possibly?
And one more thing I forgot to mention is that I had forgotten to unplug the battery when I pulled the pcm, would that cause anything like this?
Old Feb 28, 2006 | 08:18 AM
96ZCamaro's Avatar
Ttt
Old Feb 28, 2006 | 10:48 PM
Give your PCM time to relearn. That's what you might be experiencing.
Old Feb 28, 2006 | 11:07 PM
96ZCamaro's Avatar
Yea, it does seem to gradualy be getting better....but not quite there yet. Thanks, I will just wait a while and see what turns out.
Old Mar 1, 2006 | 12:15 PM
fast96lt4's Avatar
Make sure all your grounds are on.
Old Mar 1, 2006 | 12:18 PM
96m6lt1's Avatar
anytime you remove your pcm disconnect your battery first,you may have hurt the pcm
Old Mar 1, 2006 | 02:43 PM
madwolf's Avatar
Try disconnecting the battery for a minute or two, then reconnect. See if it gets any better.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Fastbird93
May 22, 2015 08:28 PM
willismoons
Feb 14, 2015 08:42 PM
jayvar
Feb 2, 2015 10:00 PM
Jan 5, 2015 07:14 PM
