Computer Tune and Opti install, cause problems with timing? ---
Old Nov 20, 2009 | 08:23 AM
AlwaysCode390's Avatar
Question Computer Tune and Opti install, cause problems with timing? ---
Hey Guys ---
I was wondering if I told the dealer I had a madz28 tune , and the dealer installed the opti to "stock specs" ... could that be off?
I dont know how to set up timing with an opti, but I am not sure if the timing was advanced when the car shut off. If the dealer reinstalled it to THOSE specs ... and the pcm re-advances it the next time its started?
I am just wondering if that could be adding to my overheating problem. It isnt throwing codes, but runs STRONGER than I remember it running ... so this came to mind.
For all I know the computer just retards timing to start up the car, then advances as RPM climbs?
THANKS ---
Old Nov 20, 2009 | 09:54 AM
Stl94LT1's Avatar
The PCM sets the timing, there is no adjustment on the stock opti.
Old Nov 20, 2009 | 11:02 AM
RamAir95TA's Avatar
Yep, there is no physical mechanism to control the timing. it's driven from the PCM as stated.
97SSdude
Dec 31, 2014 07:43 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
GigaMp3z
Feb 20, 2003 02:57 PM
