Compression question
Old Jul 7, 2008 | 05:39 PM
Ekof96Z28's Avatar
I have a Stock block deck, stock head gaskets, stock combustion chambers, stock valve.
My heads were milled 5 thousandths. .005. Will that have any effect on compression ratio in a 95 LT1 with aluminum heads.
Old Jul 7, 2008 | 06:16 PM
Stl94LT1's Avatar
Very little.
Old Jul 7, 2008 | 06:18 PM
Ekof96Z28's Avatar
Yeah, I knew that. I was just curious if it would be .1 or less or if anyone knew what it worked out to be?
Old Jul 7, 2008 | 07:56 PM
Jazsun's Avatar
If you would have gone w/ the impala headgaskets or felpro 1074's it bumps you up .2-.3 ish. The people I asked said the 1074's bump you from 10.4:1 to 10.7:1 the impala is probably even more.
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
Red_94Formula
Jan 22, 2015 12:17 AM
