compression on my 383??
Old Jan 30, 2004 | 04:34 PM
  #16
rskrause's Avatar
Moderator
Originally posted by viperkiller
well i'm going with the xe 230 236 112
the reason i'm asking is a lot of you know more then i about this stuff and i want the most i can get with what i'm doing and still run the 93 pump gas.
thanks for your help
I will run the numbers when I get home (I am at work).
Rich Krause
Old Jan 30, 2004 | 04:45 PM
  #17
WS Sick's Avatar
I hate it that the small town I live in has 91 as the best gas I can get. I went with a KB piston with an18cc dish , my afrs started with 53cc chambers and were cleaned up a bit, they were just above 51cc after. I used the fel-pro gasket. The cam I started with was the XE 224/230 on 112, it ran fine on 91, but power was not what I wanted. I switched to the cam youre going with(230/236 XE on 112) it still has none to very little knock and runs much better. I got a real deal on an GM 12370847 cam and will be popping it in this winter , along with a thinner head gasket. We'll see what happens.
Old Jan 30, 2004 | 05:39 PM
  #18
97Z-M6's Avatar
hey viperkiller (brad) didnt you forget to metion you want to spray. ehy try to find your spec card. so we can look at all the valve timing events.
Old Jan 30, 2004 | 05:40 PM
  #19
jonaddis84's Avatar
Originally posted by slopokrodrigez
You didn't waste your breath, some of us paid attention.
So what ratio did your engine end up with? Does it have a detonation problem?
Mine WILL end up right at 11.1:1 most likely. Im running SRP blower/nitrous pistons, so theyre dished 16cc, so it would be almost impossible to go much above that without having too short a quench height.
Ill end up with 52cc chambers, according to Lloyd, thats about as far as you can go without having to mill down the intake as well.
.039 felpro head gaskets
.005 deck height
This puts me at .044 quench height and 11.1:1 Static comp ratio
Wont have any problems here with detonation
I was speaking above after hours upon hours of research and reading on the subject, and a few buddies in town running that high no problems.
Old Jan 30, 2004 | 08:32 PM
  #20
97Z-M6's Avatar
ttt for ya
Old Jan 31, 2004 | 12:07 AM
  #21
rskrause's Avatar
Moderator
I think your CR is too high for that cam. With a flat top and a 57cc combustion chamber I calculate a DCR of 9.2:1 with a 4.030" bore, 3.75" stroke, and a 0.045" gasket+deck height.
Rich Krause
Old Jan 31, 2004 | 11:29 AM
  #22
akafred's Avatar
12.5:1
I run 12.5:1 in my 383 camaro with sunoco ultra 94, with a hotcam !
I have no problems with this combo at all
Old Jan 31, 2004 | 01:09 PM
  #23
gb95zconv's Avatar
What would be the problem with running a quench of say .030 or so.....I know .035-.045 is optimal range but why?
Old Jan 31, 2004 | 03:25 PM
  #24
jonaddis84's Avatar
Parts tolerances.
Ideally it would be great to have the piston just touch the head when it hits TDC, but we all know that cant happen
So for parts that stretch/expand/piston rocking you have to leave yourself some room in there so they dont touch, even more room with aluminum rods.
.035-.045 is recommended range, but over .040 is even more recommended on a not so high budget motor with awesome parts and machining.
Old Jan 31, 2004 | 03:27 PM
  #25
rskrause's Avatar
Moderator
Parts tolerances.
My motor has high buck parts and I still use 0,045". As John says, too close and the piston can "touch" the head, which is NOT a good thing.
Rich Krause
Old Jan 31, 2004 | 03:34 PM
  #26
jonaddis84's Avatar
Wouldnt a race type motor with say titanium rods be able to run a closer quench than that though? I thought I had heard somewhere it WAS possible, just not recommended.
Old Jan 31, 2004 | 11:24 PM
  #27
viperkiller's Avatar
yea maybe in a year or so,i'll deal with that at the time. i will prob. just give it a little shot and pull the timming?? i just want this compresion to be right now.
thanks alot rich, if you have time could you tell me what i should shoot for to keep it on pump gas, i'm guessing around 11.5 from what i've been reading.
wssick what is your deck hight, compression ect
Old Feb 2, 2004 | 09:58 AM
  #28
WS Sick's Avatar
My deck height was untouched since the block was flat so its as it comes from the factory, I calculate my compression ratio to be right around 11:1 with the standard deck height, with a 0 deck and this set-up it calculated to be 11.6 I do beleive.
Old Feb 27, 2004 | 04:17 PM
  #29
Aggie7732's Avatar
Okay, my engine shop is putting together a 383 for me with a 306 cam, what's the highest static compression I can run and still use pump gas?
And what about if down the road I want to run a supercharger?
-Sean
Old Feb 27, 2004 | 09:52 PM
  #30
jonaddis84's Avatar
-Sean
I wonder how many times this question can be asked on this board before people realize there is no set number?
