Compression Check?
Old Feb 29, 2004 | 06:56 AM
ChevyIron's Avatar
Compression Check?
I am like the subject says want to give my motor a compression test.I went to shoeboxs sight to see how I have to do the test it said the car has to be warm.My question is I dont want to start the car due to some problems Im having with it.Will I be able to get a accurate reading with the car cold?
Old Feb 29, 2004 | 08:04 AM
If you have to do it cold, then do it cold. Warm is probably more accurate because of thermal expansion of the parts. How much difference there is in the readings, I am not sure.
Old Feb 29, 2004 | 09:08 AM
ChevyIron's Avatar
Thanx Rob
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
