Completely replacing Optispark system
Old Jul 20, 2004 | 08:41 PM
karlmarxxx's Avatar
Whats the best way to completely get rid of the optispark in a late model Fbody?
Old Jul 20, 2004 | 09:06 PM
944v8inDFW's Avatar
Re: Completely replacing Optispark system
Sell the car. or spend an a** load of money getting a custom system built. If you want to go real retro rip off the intake and put a carb style one on and run a points type distribitor. Dont know why the opti gets such a bad name all it does is be an electronic ignition. Just like all car parts they need attention from time to time. Seems like people tend to blame all lt1 running problems on the opti, when most are from lack of basic matience. Whew ... end of rant! The opti is your friend!
Old Jul 20, 2004 | 09:20 PM
kmook's Avatar
Advanced Tech Moderator
Do a search it has been discussed at least 10 times over. Fred (Injuneer) and others have gone into detail. There are a few difrent ways, but none cheap or easy at this point. If the Delteq stage 2 comes out any time soon, then that should be a good solution.
Old Jul 20, 2004 | 10:06 PM
texanmutt's Avatar
It would be realy nice if someone would make one.
Old Jul 20, 2004 | 10:40 PM
karlmarxxx's Avatar
The opti is definitely not my friend. I need to get rid of it all together cause it interferes with my fluidampr damper. If I go the carb route, I assume I will need the computer to control the stock guages. Will I be able to get a tach signal to it off the coil? Or would I need to install a crank trigger.
Old Jul 20, 2004 | 10:50 PM
944v8inDFW's Avatar
I would get rid of the aftermarket damper long before i got rid of the opti. Unless you are doing something really special with the engine and got a ton of money to spend and if you got tons boy do i have a car for you! I use a stock damper amd twist 6000 plus on a regular basis. Like kmook said full replacement has been beat to death do a search.
Old Jul 20, 2004 | 10:54 PM
bunker's Avatar
I turn 7000rpm every time I race & always have with all my setups with no probs, crank never spins I marked it.
DirtyDaveW
Dec 1, 2016 05:37 PM
alphaauto
Feb 5, 2015 05:25 PM
Jazsun
Dec 29, 2014 12:14 PM
