Complete LT1 Gasket kits ?
I did a search yet i wasn't able to find much on this topic.
I'm looking for a COMPLETE engine gasket kit, where could i get it and ofcourse the best bargain.
I do intend to use Felpro's for the heads, intake and headers but buying seperate kits or even buying all remaing gaskets seperate would cost more than buying a complete kit and using Felpro's in certain area's.
Any advice or experiences ?
Re: Complete LT1 Gasket kits ?
Summit lists a Trick-flow full set (part # TFS-3140091 for 318.95), You can also buy the complete set in two parts from O'Reilies for just under 200$ (fel-pro) You just have to buy an upper and a lower kit, together they have the complete set.
Will check out O'Reilies.
Did check on Ebay but not been able to find a complete setup, will keep an eye on it though.
Thanks !
UPDATE: Just found one, thanks again !
Thanks !
Haven't heard of any except the Trick Flow one that was listed. I just ordered them all seperately from Fel Pro and Dal Slabaugh.
If you check out Thunder Racing or Combination Motorsports, they both sell gasket packages, but not complete engine ones. If you buy a couple different packages you can get most all gaskets, with a couple repeat gaskets/seals.
Kind of sucks.
Dave
Kind of sucks.
Dave
CARiD
Dec 26, 2014 04:20 AM
