Complete engine rebuild parts list
Old Mar 26, 2003 | 03:45 PM
notstock4long's Avatar
Am I missing anything?
crankshaft
connecting rods w/ bearings
pistons
piston rings
all gaskets
cam
lifter
spring w/ seats, shims, locks and retainers
freeze plugs
pushrods
1.6 rr's
Old Mar 26, 2003 | 04:39 PM
95CamaroZ-28's Avatar
Timing set, and the way you said "connecting rods w/bearings" makes it seem like you mean rod bearings only. If that's the case, you need to add cam bearings and main bearings to your list. Other than that, I believe you have all of the parts under control. Now it's just figuring out what brand and type of those parts you want.
Old Mar 26, 2003 | 08:16 PM
Yup...thats gonna be the hard part. I thought main bearings were the bearing around the big end of the rod, but I guess not. I am still trying to learn more. I want a stock bottom end, but a medium size cam, I would like to have around 350hp. I also plan on getting the heads ported.
Old Mar 26, 2003 | 08:46 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
main bearings are what the crank spins on
rod bearings are what the rod spins on
cam bearings are what the cam spins on
you might want to include a water pump, valve seals, rear main seal (a gasket in effect) oil pump, oil pump drive, pickup, injectors, new head.intake.main bolts amongst other various bolts.
Lots of fluids, beer and patience
Old Mar 27, 2003 | 04:59 PM
That is the key to doing this engine rebuild. Without either of those, it will never get done.
Brandon Wittmer
Dec 20, 2014 09:51 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
