competition valve job
Old May 9, 2005 | 09:52 PM
LastLT1's Avatar
ok im getting ready to get my heads ported out but in order to do that i need to get a valve job done. now i heard there are 2 kinds of valve jobs, a regular and a competition. now what kinda performance improvement can i see out of the competition? they said the would do a three angle cut, and if i do do this then when i port my heads, what size flow should i get? i am planning on getting my intake manifold proted too so if anyone has any ideas on what size flow i should do that too then please give advice.
Old May 9, 2005 | 10:43 PM
blackztpi's Avatar
Re: competition valve job
well, thats pretty open ended, but here's what i have heard before.
3 angle valve job about 15 hp alone. polishing the stock designed head gets you about another 20-25 and porting is very differentiated.
Old May 9, 2005 | 10:59 PM
SStrokerAce's Avatar
Well a standard VJ (valve job) can have a wide seat on it... which means the place where the valve touches the head.. This is not really good for flow but good for long life. You want to find a balance of great flow and something that will live a long time. Usually a "competition" valve job will have 3,4,5 or more angles in it and might have some backcut on the valve and some blending done into the port....
Robert Yates said that a VJ is half of a cylinder head and it really is... gotta do a good VJ to get good numbers.
bret
Old May 10, 2005 | 12:14 AM
MachinistOne's Avatar
A regular VJ is 3-angles. A comp VJ should be a minimum 5-angle, we do what is called a radius valve job, there are no angles, just a smooth transition, with a backcut the flowbench shows a 30% improvement.
As said above the seat width and placement is a big part of this too, this depends on how much spring pressure there is and how long you wnt the VJ to last....Flow vs. longevity.
Old May 10, 2005 | 09:22 PM
LastLT1's Avatar
well in that case then is it a good idea to get the competition valve job done? and if not then what kinda job should i get done then. cause i want to get the most power out of these heads as possible. and if u guys can give me some advice then that would help out alot. also what kinda porting should i get on my intake manifold?
Old May 10, 2005 | 09:30 PM
96m6lt1's Avatar
i sure hope you get the portwork done before the valva job!
3-angle is common
5-angle if you are all out racing to benefit from it.
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
Catmaigne
Jul 14, 2015 05:17 PM
