Comp XE Users Inside
Look into the Crane 99893 dual springs, you use them with all other comp cams hardware, retainers, locators, and locks. The handle almost .700 lift and they have perfect seat pressure, I also believe they require no machining somehow.
I used the 986s with my 224/230 and compcams lifters for like 2 weeks before the motor sploded
Originally posted by FacelessZ
No machining required for those springs?
Also, be mindful that this spring is pretty stout for the street at an average spring rate of 408lbs/in. so be doublely sure of your installed spring height so you don't end up with too much pressure for a daily driver.
This is all coming from Nick at Nutek. He suggested for my 381 setup and LE heads, to run the Crane 99893 springs with compcams 4770-16 seats (locators), 740-16 CC chromemoly retainers, and 10* CC superlocks 613-16.
I, on my previous setup with XE224/230 ran the CC 986-16 springs with all the other CC hardware listed above, and there was no machining of the heads required. I belive the 99893 spring is slightly larger than the locator, but it is still within a diameter allowed by using stock heads.
He suggested these above all other springs, even other CC springs that handle more lift than 987s and require machining just because he found they have the best seat pressure and handle a great amount of lift of any spring, needing a spring that would fit in stock heads was not a requirement for me either.
I've had pretty good success & longevity running springs like comp's 985 & 977 on the more aggressive XE stuff. That's with good oil pressure & 875 lifters
Don,
Comp's locators (like those 4770's) are generally .060"
.Don,
Don,
.Don,
It just depends on the lobes you run really where I'd set up either spring. FWIW, the 985's at approximately 1.800" will handle a wide range of stuff pretty effectively in my experience & the 977's usually end up at 1.85-1.90ish.
Originally posted by Don 97 SS
Thanks. Can you tell us what spring (open) pressure you generally set those CC 895 and 977 springs at for a performance/street car? I'm always concerned about have the right pressure and worried about either too low or to high problems.
