comp ratio and spark plugs (heat range)
Old Apr 28, 2003 | 08:29 PM
Fbody1's Avatar
Talking comp ratio and spark plugs (heat range)
does your comp ratio have anything to do with what heat range you run?should i run a hotter plug (i have 11.4 comp ratio)and will i gain any hp? right now i am using stock heat range any suggestions for my comp ratio?and what are the benifits of running a hotter or cooler plug
Old Apr 29, 2003 | 04:06 PM
Fbody1's Avatar
somebody, anybody , someone knows? or do they?
Old Apr 29, 2003 | 05:48 PM
PoorMan's Avatar
I would say go to a colder plug with your compression. Less chance of preignition.
Jeff D.
Old Apr 29, 2003 | 08:15 PM
Kory 88 Iroc Lt-1's Avatar
I'm running ngk tr6's I have about 11.1to1 they seem to work better than my stock heat range plugs did.
Kory
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
racecarz28
Mar 30, 2015 09:55 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
