Comp 'R' Lifter Failure
Old Apr 25, 2005 | 09:51 AM
  #31
JustNO's Avatar
Re: Comp 'R' Lifter Failure
Originally Posted by tardy007
Cr*p, I have the 875 lifters still in the packaging and planning on installing in a few weeks. Hopefully someone knows how to tell if these are the old style or the new and improved style or maybe I should stick with the stock lifters
875 lifters are the old style??? Don't change your order, I think 875 'R' style is a good choice,but its important to do that as Comp recommends 1/16 turn past zero lash with the Comp R's ..
Old Apr 25, 2005 | 09:52 AM
  #32
tardy007's Avatar
Originally Posted by HungryT/A
Look at my pictures in the first post, they're the old style.
Guess I will open up the box when I get home. I'll keep an eye open to see what the pics of the new style look like so that I can compare.
Old Apr 25, 2005 | 10:10 AM
  #33
JustNO's Avatar
You see lots of problem because people don't know exactly how should they use them..people who get suggestion from comp (about installing), have no problem about this..
Old Apr 25, 2005 | 10:48 AM
  #34
Mystic97Z's Avatar
1/16 isn't enough, i had mine at 1/4 turn past zero lash and they were noisy as f*ck,, until 3/4 turn past zero. i actually started with 1 full turn past zero and the car ran great..
Old Apr 25, 2005 | 11:26 AM
  #35
JeffK's Avatar
Just curious about something....
Did you look in your oil pan after this happened? Particularly, the magnet on the plug.
Old Apr 25, 2005 | 12:05 PM
  #36
Loadre's Avatar
I've had two of the pushrods cups come out on my Comp R's as well. Pieces of ****.
Old Apr 25, 2005 | 12:08 PM
  #37
Heatmaker's Avatar
Advanced Member
Damnit I hate this site!!!
Just soon as I get my parts lists together and start making calls you guys come up with this thread. Now just what kinda lifters should we get?
Old Apr 25, 2005 | 12:11 PM
  #38
tardy007's Avatar
I am in the same boat!!!
Old Apr 25, 2005 | 12:13 PM
  #39
Loadre's Avatar
Advance carries Sealed Power stock replacements. Good stuff.
Old Apr 25, 2005 | 12:29 PM
  #40
Z95m6's Avatar
Originally Posted by bunker
This being the case because I bought new springs/lifters and 1 spring failed from Comp which is a 977 spring, broke in 3 pieces, and 1 lifter failed, and no the lifter is not the same one driving the failed spring, lifter failed was #1 intake and valve spring failed was #8 exhaust, makes me think twice about Comp's quality control.
Just a little story i have, when i had my 428cj built for my Mach 1 the engine builder chose a comp cam. He installed it and i broke it in. It went flat. I then took it back to the engine builder and he installed a new comp replacement cam and we broke it in again. I drove the car home and it still wasn't running right. I pulled the valve cover and what do you know it flattened the cam. The 3rd time we installed a crane cam and broke it in. The cam broke in fine and has been running great for 4 years now. After that i told myself i would never buy a Comp product again. Then i joined this board and everyone preaches that Comp is the best. So i gave them another try when i ordered my comp 230/236. I did install it with out degreeing the cam, which was a mistake. Comp had ground it wrong, so i had to tear the motor apart to degree it. It was my mistake for not degreeing the cam the first time but i"ve never had a good comp product. Now i'm starting to think my Comp R's are making to much noise and might of come apart.
Old Apr 25, 2005 | 01:45 PM
  #41
JustNO's Avatar
Mee too..! I just prepared a top notch quality 383ci LT4 Long Block,but couldn't decide the valvetrain.. As you know valvetrain components is the most important thing of the engine..
I probabily will go with R style lifters,but I'm worry about it..
Old Apr 25, 2005 | 02:05 PM
  #42
1-bad-z28's Avatar
don't be worried, just don't use them. Every other one of these things seem to fall apart. That is too much money to throw away. I have also heard that comp won't do anything about it because it is always blamed on the installer. Who has ever heard of an oem lifter falling apart like this. I know that an oem lifter is only good to a certain amount of spring pressure but what are you supposed to do past that? I definetly wouldn't use comp r's. I just don't know.
Old Apr 25, 2005 | 02:30 PM
  #43
SVThuh's Avatar
Does anyone here know if it would be possible to pull a stock lifter apart and re-use the retaining clip on the Comp R's? This seems like it would be the best option if the retaining clips are the issue on these things coming apart..
Just an idea.. Has anyone tried this yet? Im curious as I am also looking into Comp R's for the new motor, but dont want to chance anything.. or spend $500+ on a set of lifters..
Old Apr 25, 2005 | 02:52 PM
  #44
JustNO's Avatar
So you say,don't use 875 lifters.. Okay which one is better than this? Is 850 better?? Or any other company do you mean?
Old Apr 25, 2005 | 03:24 PM
  #45
Z95m6's Avatar
The 850's are just OEM replacements, so if you aren't gonna run Comp R's you might as well just keep your stockers. As far as i know there isn't really any other alternative between stock and the R's. I went through this back a few years ago when Comp R's were on back order for months and no one could get them. The only other option was OEM stuff.
