comp pro mag rockers noise?
Old May 19, 2008 | 03:34 PM
Slowmaro95Z28's Avatar
I just finished my cc306 swap last week and I noticed some noise during the first startup. After going through my heat cycles for the valve springs the sound died down a lot but comes and goes. I know I adjusted everything properly. I used Shoebox's site for the procedure. Is this normal for these rockers. They are nsa and I'm using GMPP guideplates.
Old May 19, 2008 | 03:43 PM
wrd1972's Avatar
They should have very faint ticking sounds being produced, sounds like a buch of sewing machines. This is normal.
Cams with higher lift may produce louder ticking than those with less lift.
If the noise seems loud then chances are you have a rocker too loose in terms of backlash adjustment. A mechanics stethoscope will pinpoint the specific rocker in seconds.
Old May 19, 2008 | 04:52 PM
slomarao's Avatar
my crane golds clicked and clacked so bad for the first 50 miles. Than slowly but surely they stopped. Well like stated above, they kind of sound like a sewing machine.
The real loud noise should stop shortly.
Old May 19, 2008 | 06:03 PM
69gto96z's Avatar
Comp pro mags are fairly loud, but like stated above it should just be a ticking, like a sewing machine. And if one of them is not adjusted properly, and is to loose, you will know it!
Old May 19, 2008 | 08:09 PM
marshall93z's Avatar
Mine get louder right at 2500 rpms then quiet back down. Not sure if it's normal... just saying what they do!
Old May 19, 2008 | 08:29 PM
lt1-xjs's Avatar
Scorpion 1.7's are quieter on mine, not to mention the 10 rwhp they gave me over my 1.6 promag's.
Old May 19, 2008 | 11:29 PM
Thanks everyone. I figured it was normal but just had to be sure. The noise is similar to a sweing machine so I guess I'm ok. I'm still waiting on my tb so I haven't driven the car more than across the street to work on other cars in the driveway. I can't wait to see how it runs.
Old May 20, 2008 | 11:05 AM
Airbornec507's Avatar
However if you have a louder noise coming from one area that is a loose rocker. You will be able to tell though. You can put your ear up to it and narrow it down to which cylinder it is. That's how I quieted mine down without overtightening any others. Now I cannot hear anything unless I open the hood and listen real close and even then the sewing machine noise is hardly noticable after 3500 miles with the new engine set up.
I have the Comp Pro Mag 1.6s NSA w/guidplates with the cc306 and that's my experience. Half a turn on 7/16 rockers is perfect for noise on this set up.
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
rje
Sep 9, 2002 12:35 PM
SABLT194
Aug 21, 2002 07:45 PM
SABLT194
Aug 3, 2002 09:33 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
