Comp pro mag nut backed out
Old Jul 28, 2006 | 01:30 AM
RedLT4Mike's Avatar
The following takes place during and after the 100 mile inspection of my valvetrain.
This is on my new 383. One of the nuts backed out completly and weakened the threads inside the nut enough to no longer be useable. It would thread onto the stud, but upon turning the engine over by hand while adjusting the valves it would back off again. We had an extra one handy.
While doing this 100 mile inspection of my new valvetrain, another had backed
off slightly, but was adjusted back into spec and it remained there.
As of now my preliminary plan if to order 16 new nuts from Comp.
Keep in mind the ones in question are used from another board member.
I understand that my valvetrain is kinda radical with the 977's, super aggressive lobes on the Joe O. cam, and Morel lifters.
Does anyone have any experience they can share with me that can help
me make my valvetrain stable?
Old Jul 28, 2006 | 02:20 AM
396D1SS's Avatar
Re: Comp pro mag nut backed out
your rockers didnt come with polylocks?
Old Jul 28, 2006 | 03:21 AM
RedLT4Mike's Avatar
yes they were poly locks just to be clear
Old Jul 28, 2006 | 03:36 AM
396D1SS's Avatar
i have had 1 of mine get loose before i got it really tight this time so far so good
Old Jul 28, 2006 | 03:51 AM
Jon A's Avatar
Use a socket adapter to get on them with a real wrench and crank them down better next time.
Old Jul 28, 2006 | 06:56 AM
cehan's Avatar
I set the valve lash with the engine running, then with the engine off, I go back and torque each one with an allen socket to 20 ft. lbs. Never had one loosen up yet
Old Jul 28, 2006 | 07:15 AM
Javier97Z28's Avatar
Moderator
Crank the polylocks down much harder. I just pulled my valve covers last night after 600 miles of runtime and the method LR and a few others suggested worked just fine.
I set mine with the engine not running this time, using the base lobe of the cam. My particular setup I used 1/4 turn after zero lash. We got to zero lash, tightened the rocket nut 1/8 turn, then tightened the polylock down. We then took the rocker nut and the polylock TOGETHER and tightened the other 1/8 turn. Takes some cranking but it's holding solid.
Old Jul 29, 2006 | 02:18 PM
wrd1972's Avatar
You can crank the poo poo out of those poly-locks. If torqued right they will not back off. Use a high quality wrench with at least 4-5" of length for leverage or a allen for a wratchet. When I went to remove all mine recently I ended up with several bloody knuckles cause those things will "snap" when lossened if they were put on correctly. I have total confidence that mine wont back off after see this.
Old Jul 30, 2006 | 03:43 AM
RedLT4Mike's Avatar
thanks guys for the replies!
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Roadie
Feb 16, 2015 10:34 AM
