Comp Pro Mag 1.6 rr
Old Feb 17, 2009 | 05:05 AM
udlose94z28's Avatar
Comp Pro Mag 1.6 rr
I have decided to get these for my rebuild, 94z28 503 cam.
I have heard its better to get the gm guideplates bc others will not fit properly? True?
And should i run these on the stock 3/8 studs, or should i buy some arp ones? 7/16 or 3/8 ?
Old Feb 17, 2009 | 06:50 AM
GM guideplates (14011051), Trickflow (30400623-8) or adjustable such as Isky sells. Some have had hardness issues with the GM plates, so test them with a file before installing.
You will need to match the stud size to the rocker you buy. IMHO, I would just go with the 7/16 for added strength.
Old Feb 17, 2009 | 03:22 PM
dubbsix's Avatar
What do you think of the Manley guideplates?
Old Feb 17, 2009 | 03:27 PM
I don't know anything about them.
Old Feb 17, 2009 | 10:46 PM
I have Manley guideplates with 1.6 Pro-Magnums. Work fine.
Old Feb 17, 2009 | 11:13 PM
u mean 7/16 top rocker arm studs right? are they 3/8 on the bottom
Old Feb 17, 2009 | 11:26 PM
All guideplates used on the LT1 have the same size holes in them. The bottom part of the stud is 7/16" in diameter, even if it is 3/8" on the top.
Old Feb 17, 2009 | 11:32 PM
BLKOUTZ28's Avatar
I got the comp 4808-8 guideplates and they work fine. They are $18.00 on summit. The studs will be 7/16 bottom and top. Stock studs are 7/16 bottom 3/8 top. There is not much of a difference between the 3/8 and 7/16 studs. Either way you go you will need to get new studs, stockers are cheaply made. Get a set of ARP's either size and you will be good to go.
I looked into the comp 1.6 pro mags and then looked into the summit 1.6's. The summit's are made by a company called Scorpion and they are made in america. I was talking to Lloyd Elliot and he recommended them to me for my budget. They are like $140.00 cheaper than pro mags and seem to work very well with most people I have talked to that have them.
raroz28's Avatar
i went with comp guideplates. i don't think you can really go too wrong as long as you get a quality name.
Old Feb 18, 2009 | 06:44 AM
I don't think the Comp guideplates align the pushrods correctly (at least I think that is what most people have found). Pretty sure they are the same as used for the SBC and that isn't right for the LT1.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Daluchman1974
Sep 11, 2015 06:12 AM
