comp cams 977 springs good for this??
Old Aug 27, 2004 | 11:42 PM
lillbush5555's Avatar
I just got this cam and was told that the comp cams 977 springs will work with it. the specs are 266int and 276exh dur @50 and .640int .649 lift with 1.6rr. the cam is ground on 108 centerline and has a 112lobe seperation it is a solid roller and I will be running 1.6 RR with it. Please help me out
Matt
Old Aug 28, 2004 | 12:43 AM
SStrokerAce's Avatar
Re: comp cams 977 springs good for this??
Matt,
977's are not even close on a setup like that. First they have way to little pressure seated and over the nose and on top of that will hit coil bind very early.
e-mail me for more help if you need it.
Valve lengths retainers, locks etc... all needs to be looked at here along with the cam specs to see what the RIGHT spring is for your your setup.
Bret
Old Aug 29, 2004 | 06:38 AM
slopokrodrigez's Avatar
Max recommended lift for 977's is 0.600 !!!!!! Coil bind height is 1.195.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
GigaMp3z
Feb 20, 2003 02:57 PM
