comp cams 503??
Old Feb 2, 2004 | 12:00 AM
97SS0594's Avatar
comp cams 503??
i picked up a cam and was lookin at the specs 224/230 114lsa it has a custom grind on it im tryin to get ahold of comp to get the lift but if i recall it has slightly more lift than a 306. is this gonna be a good cam for my car?? im just in a doubtful mood tonight for some reason tonight. should i put this cam in or should i order a 306??
Old Feb 2, 2004 | 09:24 AM
http://www.compcams.com/Technical/Ca...ML/198-199.asp
The 306 is going to have more lift and be a much more agressive cam since it is 112 LSA.
Old Feb 2, 2004 | 09:30 AM
Camaro_Guru16NY's Avatar
Which would be more aggressive though,? a 112 LSA or a 110 LSA on the CC306? the lower the number the rougher the Idle right?
-JOhn
Old Feb 2, 2004 | 09:35 AM
-JOhn
Yes.
In a nutshell, the lower LSA raises the power band. Idle will be more lopey.
Old Feb 2, 2004 | 01:08 PM
97SS0594's Avatar
so mt 114 isnt gonna be very lopey
Old Feb 2, 2004 | 01:45 PM
RacinLT1's Avatar
114 lsa is gonna idle pretty mildly.
Old Feb 2, 2004 | 05:29 PM
Yeah, the 224/230 114 is bumpy, but not lopey, IMO. I am currently running one. It's mild enough to run with the stock A4 converter and not be bothersome.
Old Feb 2, 2004 | 05:36 PM
eagleknight97's Avatar
So running one with a 112LSA with the stock converter might not be the best idea??? I would like a lopey idle, but dont really want a converter, cuz im not really gonna be going to the track.
Old Feb 2, 2004 | 05:39 PM
97SS0594's Avatar
yup im sellin it then, not nearly big enough im sorta new to the whole cam thing, but i dont drive the car alot. id like to touch the 400 mark and this cam i dont think is gonna do it. looks like its goin on ebay. thanks for clearin it up!!
Old Feb 2, 2004 | 05:58 PM
neil350's Avatar
See Rob if you had a little info on your Z28 on your page, we would have known this.
Old Feb 2, 2004 | 06:18 PM
It is mentioned on my mods page, but does not describe the lope. Guess I need a sound clip, lol!
Old Feb 2, 2004 | 06:32 PM
97SS0594's Avatar
can i spray safely on a 112 lsa??? i think im gonna order a 306
Old Feb 3, 2004 | 11:38 AM
So a cc306 in a M6 and 110 LSA will be pretty good lopey idle with a good tune but make sick power?
-JOhn
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
