Tune Up!!!
Old Feb 2, 2004 | 09:42 AM
ppmz28's Avatar
Tune Up!!!
I am pretty sure I need a tune up. Can someone that has recently got this done tell me around how much it is for new wires and plugs!!! Thanks!!!
Old Feb 2, 2004 | 10:18 AM
Red96Lt1's Avatar
You can probably get plugs and wires for $65 or so. I went with Taylor OTVC (over the valve cover) 8mm wires for $100 from thunderracing.com. Plugs are $2 each, unless you get some really expensive plug (like I did).
Old Feb 2, 2004 | 10:24 AM
FacelessZ's Avatar
Just go with the NGK TR55 plugs (TR6 if you're running N2O)...they should be less that $2 a pop...
As far as wiring goes, a stock replacement will be fine...no need to go with the thicker gauged wiring...
Old Feb 2, 2004 | 11:22 AM
ibanez6rg's Avatar
There's a lot more to a tune-up than just plugs/wires.
Old Feb 2, 2004 | 12:21 PM
FacelessZ's Avatar
No way...
Old Feb 2, 2004 | 12:32 PM
ibanez6rg's Avatar
Originally posted by FacelessZ
No way...
What I got from the thread is that he is just doing plugs/wires and that's it!
buy my rev kit
Old Feb 2, 2004 | 12:33 PM
FacelessZ's Avatar
Yea buy the rev kit off of Mr. Ibanez. Forget about your plugs and wires and all that other tune-up crap...jump straight for the "100 horsepower increase" on your top end
Old Feb 2, 2004 | 01:07 PM
tmuti13's Avatar
what is the best way to get to the plugs/wires? Is it to take the y-pipe off? I have to give my 97 a tune up too and I am just looking for some tips/tricks. Thanks.
Old Feb 2, 2004 | 01:46 PM
BigJustinZ28's Avatar
my secret to doing the plugs and wires easily is to find someone that is more patient than me and put money in his hand. I did however stick a set of taylors spiro pro's and ac delco platinums in his other hand of course.
Old Feb 2, 2004 | 03:10 PM
Robs97Z28's Avatar
plug and wire are a big pain in the butt. remove the exhaust, the starter, belt, alt, loosen the power steering pump,and battery for the extra room.
Old Feb 2, 2004 | 03:17 PM
camaroguy287's Avatar
All i removed was the alternator. Thatz really all you "need" to remove. Of course my arms and hands got a tiny bit cut up. And it took some patients and time to find the holes for the plugs. just kinda feel around for awhile,lol.
Old Feb 2, 2004 | 03:27 PM
ppmz28's Avatar
I was looking for more of the price a mechanic would charge to install it! THANKS!!!
Old Feb 2, 2004 | 03:40 PM
EbeZ28's Avatar
Just did the driver side+coil wire this weekend (plugs and wires). Didn't have to remove anything except the intake to get to the coil. The plug 2nd closest to the firewall was a serious PITA. Ijacked the car up nice and high and did all plugs from under the car. Passenger side is a different story. I'm gonna drop the Y pipe and hopefully I'll have enough clearance to get the plugs out and the wires run.
Changing the front cover gasket was less of a pain IMO.
Good luck
Old Feb 2, 2004 | 03:42 PM
Fux0redImages's Avatar
More than you want to spend.
Old Feb 2, 2004 | 05:53 PM
AxeGrinder30thZ's Avatar
Don't pay some guy to put in plugs/wires. Do it yourself with some time and patience.
