Comp Cams 292xfi
Old Aug 17, 2006 | 05:03 PM
WALLY1
Guest
Posts: n/a
Comp Cams 292xfi
Has Anyone Used This Cam In Their Lt1. This Is The Cam That Comp Suggested For My Set Up. Its A 242/248 Dur With 584/579 Lift At 113degrees. THIS WILL BE IN A 383 WITH TRICK FLOW HEADS. APPROX 11.2 TO 1 COMPRESSION. THIS IS NOT A STREET DRIVEN CAR. ANY HELP WOULD BE APPRECIATED.
Old Aug 18, 2006 | 01:36 PM
JustNO's Avatar
Re: Comp Cams 292xfi
May cam is very similar (240/246dur. 112.7lsa)
You should give some specs about your engine.
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
