comp cam xe 224/230 112lsa
Old Sep 7, 2003 | 07:48 PM
2MUCHZ's Avatar
I just bought this cam and 1.6 RR comp springs... i planning on putting them on a high mileage but well taken care of lt1 (130000) miles...Is it ok to do this will i run into any problems is there anything else i would need (pushrods) or anything at all....Your help is greatly appreciated....Also what would the power gains be ????or 1/4 mile times on the car in the sig thanks
Old Sep 7, 2003 | 08:51 PM
1.8ttolt1's Avatar
i have the same setup w/ with the same number of miles. sorry no numbers for ya but the car runs great. hope ya have a good clutch.
Old Sep 7, 2003 | 09:02 PM
Z95m6's Avatar
well i would say you have a 50/50 chance. Some people get by fine while others spin bearings.
Old Sep 8, 2003 | 04:57 AM
2MUCHZ's Avatar
TTT
Old Sep 8, 2003 | 05:57 AM
Fastbird93's Avatar
Well, while not as high mileage as yours, see sig for numbers w/really well ported heads.
No problems noted. My block was damn near perfect when we had the heads off. Still had cross hatching in the cylinder walls.
Old Sep 8, 2003 | 01:46 PM
Don 97 SS's Avatar
Re: comp cam xe 224/230 112lsa
Those are more miles than I would be comfortable with. But if your on a budget you might want to chance it.
I would recommend adding a new LT1/T4 GMPP HD chain set, lifters while you're in there. Don't forget new seals on the timing cover. Not cheap, but you 've got the engine apart and now would be the time to replace those wear items.
Old Sep 8, 2003 | 01:53 PM
JaysDropTopTA's Avatar
hardened pushrods and new lifters... Comp R's if ya can afford it.
Old Sep 8, 2003 | 02:48 PM
LimitedEd1LE's Avatar
The hardened push rods are basically the same as the stock push rods. I would suggest the Comp Cam chromoly push rods if you plan to go that way. Although I would suggest some new lifters because with 130,000 miles on them I wouldn't be surprised if they are a bit weak.
The only reason I have the hardened push rods is because they cam free with the cam kit I got from www.cmotorsports.com
Old Sep 8, 2003 | 05:54 PM
2MUCHZ's Avatar
thanks alot for all the information anyone else's opinion.....
Old Sep 8, 2003 | 06:29 PM
gb95zconv's Avatar
New lifters.....and at least a new stock timing chain.....Extreme Duty set would be even better if you can afford it. Hardened push rods should be fine if you have those.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
Wicked
Jul 25, 2002 04:19 PM
