Comp Cam Extreme cams
Old Apr 19, 2004 | 07:56 PM
Crazyboy's Avatar
Is there a listing of the comp cam extreme series of cams?
I need detailed info like advertised duration, .050" duration, ls, lifts, centerline an advance ground in to chose a new cam.
Old Apr 19, 2004 | 08:05 PM
muraoka's Avatar
try looking at combination motorsports. they have a pretty good list.
matt
Old Apr 19, 2004 | 08:59 PM
rskrause's Avatar
Moderator
Re: Comp Cam Extreme cams
www.compcams.com lists all of the XE lobes. You can mix-n-match them anyway you want. The cams the CM lists are not "stock" grinds but are "customs".
Rich Krause
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alex5366
Feb 17, 2015 08:12 PM
