Comp 986 springs...
Old May 10, 2005 | 04:04 PM
84 monte SS's Avatar
Comp 986 springs...
Im using comp 986's withmy cc306 swap. What all do i need to get to run these springs, can i use stock locks/retainers or do I need specific ones. I saw in another post that you need to use locators with these springs is this true?
Thanks in advance..
Old May 10, 2005 | 05:56 PM
Re: Comp 986 springs...
To the top
Old May 10, 2005 | 05:59 PM
raroz28's Avatar
you might be able to use the stock retainers and clips, but why would you? Not worth it's weight in gold for the peace of mind you get with new stronger ones. Retainers and clips should cost around 90 bucks. I would def. upgrade those. I dropped a valve because I upgraded springs without upgrading retainers and clipse. Put a hole in the top of my piston. Not fun.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
