coming home from church my ta dies whats wrong with it ?
Old Jan 28, 2009 | 10:17 PM
ghost stripes's Avatar
i have a 95 trans am i was driving home and the car just dies the battery gauge says the battery is dead but the lights windows and everything works ...so i put a jump box on it and the gauge is still below 8 volts when you try to start it nothing happens no starter turning no nothing any ideas on what it is ? thanks for any info
Old Jan 29, 2009 | 07:41 AM
'94 Bad A Z28's Avatar
Sounds like your ignition switch took a turn for the worst, it's only like a $27 from the dealer, but a PITA to change.
Old Jan 29, 2009 | 12:25 PM
checked the battery today and the volt meter said it has 12 volts solid ...but the gauge on the dash says below eight which 8 is the lowest it goes...why wont it start would the ignition switch make the gauge stay below 8 when the rest of the gauges read right ...it wont turn over or nothing ....
Old Jan 29, 2009 | 08:20 PM
94zrag's Avatar
I'd double check all of your ground wires and make sure there connected and clean. I had a similar problem to yours and it turned out to be the ground on the motor mount was off.
Old Jan 30, 2009 | 11:54 AM
BUBBA's Avatar
....happened on the way home from church? Maybe you didn't put enough in the collection box.
Sounds like a bad battery and/or connections. You can have a bad battery and still have lights, but not enough juice to start the engine. This is often caused by bad terminal connections, so check the battery terminals and the cables thems selves. If your battery is even close to being out of warranty, it is probably time for a new one. JMHO
Old Jan 30, 2009 | 12:35 PM
thanks for all the info i will change the battery and try it then check my grounds and see if thats a problem ...i will post after i do this ....thanks again and i did put enough in the collection plate i am very faithfull with that...lol
Old Jan 30, 2009 | 12:40 PM
MTBSully's Avatar
maybe you didnt pray hard enough?
Alex Barnes
Jan 24, 2015 10:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ModdedNerd
Dec 18, 2014 10:52 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Ricardo
Nov 29, 2014 10:58 AM
