Cometics with copper spray?
Old May 10, 2005 | 01:21 AM
atljar's Avatar
Anyone used the copper spray with cometics and still have them leak?
Old May 10, 2005 | 01:38 AM
SStrokerAce's Avatar
Re: Cometics with copper spray?
Jared.... Only reason them puppies leak is due to the surface finish on the heads and block. I have the tool to measure that which makes it easier to check, if you don't have a smooth enough finish then those bastards leak.
Bret
Old May 10, 2005 | 05:11 AM
rskrause's Avatar
Moderator
What Bret said. They are very unforgiving of improper surface prep, any MLS gasket is. Not only does the surface have to be smooth, it has to be flat.
Rich
Old May 10, 2005 | 10:22 AM
atljar's Avatar
Ive read a little on the Ra of the machine work, problem is i have no idea what mine is. As the two of you are telling me, and as i have read everywhere else, that seems to be the biggest deal when using cometic gaskets.
On ls1 tech it seems to be pretty common to spray them down with some copper and I didnt see anything not seal after that. I would assume the copper spray is enough to get into the microscopic finish and have them hold.
Old May 10, 2005 | 12:35 PM
Yeah i've seen that on felpros too for high cylinder pressure setups.
The Ra on the heads and block has to be below 60. Only way to tell is with a profilometer.
Bret
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
