Cometic headgaskets on LTx engine issues
Old Mar 22, 2006 | 10:47 AM
tjwong's Avatar
Has anyone here used the Cometic MLS style headgaskets on a LTx engine and experienced oil seepage at or near the number 7 or 8 cylinders. I have a problem with oil seeping out near the inside head bolt just below the 7 and 8 exhaust ports. Oil is not coming from above at the valve covers nor is it coming from the intake china wall area.
Old Mar 22, 2006 | 11:58 AM
SStrokerAce's Avatar
Re: Cometic headgaskets on LTx engine issues
Did you use copperseal spray on the gasket?
How well are the heads and block machined?
Bret
Old Mar 22, 2006 | 03:45 PM
tjwong's Avatar
Bret
Hi Bret, the block was prepped for use of the MLS gasket. When I discovered the leak that was my first question to the machine shop, as I told them what gasket I was intending to use. I didn't use the copperseal spray. I was told by cometic NOT to use any sealer on the gasket. Now I wish I had........is that a requirement from your experience??
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jan 5, 2015 07:14 PM
