Combination Motorsports ex 612 valvesprings
anyone use these? my LT1 has roughly 30K miles on the crane dual springs w/ the comp305 cam. I think i will change out the springs just for preventive maintenance
would these work well w/ my comp305 camshaft and Crane "gold" 1.6 roller rockers which I have??
I'm about to make a call to Cmotorsports for the springs but would like some input.
also when changing out the springs, all i really need is just to compress the cylinder w/ air (got the tools needed) to hold the valves up...then have at her w/ the spring change right? nothing needed to hold up the pushrods or anything? I'm sure it's a stoopid question but i just gotta ask. thanks guys
and yes i know how to reset my valve lash when i put it all back together
-Ben
-Ben
Re: Combination Motorsports ex 612 valvesprings
i have been reading up in this thread:
http://web.camaross.com/forums/showt...2+valvesprings
It looks like the failure is a freak thing.....and lots of people have been having good luck w/ the CM ex 612 springs.
only thing though, from me changing from a dual spring to a single spring....would I lose a little "reliability" in the valvespring or no? I guess for a 100 bucks, i could settle for changing the springs out again in 20K miles :dunno:
612s should be fine with that setup. Dont bother with compressed air, the valves cant drop through the heads on a stock stroke motor, and the valve seals will hold the valve up enough to get the spring on. Pushrods you just pull out, and set new ones in. Pretty basic
RUENUF
Mar 13, 2016 03:37 PM
