Combination Motorsports 612 Spring FAILURE
Re: Combination Motorsports 612 Spring FAILURE
I've got CM valvesprings - running up to 6600 rpms.. and the old lift was .598 / .608 .. No broken springs. New cam lift is a little less - but still... i'm yet to experience a problem.
PS - They've been in the car nearly two years.
Originally Posted by got_hp?
talk about overreaction
"like, oh my god, 1 spring failed, so everyone should junk this entire brand of springs!"
thats like when one persons fbody breaks down, everyone else should sell theirs.
any high performance product if going to have occasional failures, its inevitable............no one makes a perfect product.
now if a large percentage of CM spring users were having the same prob, then youd have a point, but this is the first report ive seen, so looks like an isolated case. you just have bad luck.
I have used these springs on ALOT of XE 224/230, GM 845, Crane 227, Hot Cam, CC 305, etc cams with no problems.
I have used them on a some cc 306 cams, XE 230/236 cams and my LE 1 cam (.550 to .570 lift) with no problems either.
At a lil over $100, It is a great bargain for a spring, retainer and lock set up that safely can handle .570 lift, 6400 RPM and produce 145 lbs on the seat and 350 open.
The next step up will be a double spring set up that will be about twice as much and usually require extra machine work for the larger spring diameter.
Good Luck.
Lloyd Elliott
972-617-5671
NightTrain66@msn.com
Good Luck.
Lloyd Elliott
972-617-5671
Got the intake, rockers off. Cam looks good through lifter bores, lifters aer OK, pushrods are ok, installed height and coil bind rechecked, its OK. Maybe I did get unlucky. Will have the heads off in a bit. TY for responding to my email lloyd
I pulled 3 broken Comp Cam (918s I believe) springs off before I put on the Ex612s. No problems so far. Not to say their springs suck..but 3 is a bit much and I didnt have the money to replace them. Sounds like you got a bad one... its bound to happen.
Update: Got the head off, head is scuffed pretty good, valve tip didnt break which is good. Cylinder wall may or may not be fixable, theres one pretty decent sized scuff on it. Piston is a bit beat up, but isnt terrible. Probably fixable with some creative sanding/buffing (any ideas on how to best accomplish this is welcome, I know and understand why you normally wouldnt do this). Head is salvageable with some work on it, needs two valves. (I/E) Still have no idea why this spring broke. Going to local head guy later, will call CM in the morning once I've made a decision about what to do with the car.
Side question, how hard is it to replace pistons with the motor in the car? May go that route if its doable, and throw some new rod bolts in as well.
I had purchased a set from FASASZ and they apparently had NEVER been used aside from having been installed. The motor was never turned so therefore the springs were never actually used.
Anyways, I never got around to using the springs and ended up selling them to help fund some repairs. The guy I sold them to installed them on his engine and INSTANTANEOUSLY broke like 2-3 springs. It makes me VERY wary of using these springs when cam time comes...
Originally Posted by WS Sick
Almost sounds like something was in the chamber besides the 2 valves and the end of the plug.
