colder cai???????
Thats exactly what I used... only I got mine from The Home Depot.
Cut a whole in the splash gaurd then dropped the vent down through it. There will be overhang on the vent so it doesn't just go right through. And you just bolt the splash gaurd and the vent. (did this with the gaurd off btw) Then I just used some wire mesh so leaves and other big crap doesn't get it.
Trevor
Trevor
Originally posted by 1996 | Z28 SS
First off... I said HAND not head
Second of all... if you cut and make an air scoop under your cai in the splash gaurd.. the wind DOES cool the air being drawn in... again all I have to say is
edit - btw.. one guy on this board gain .04 in the 1/4 mile just by adding the air scoop.
Trevor
Trevor
If you aim a fan on a thermometer it will not drop in temperature (assuming it is not at a temperature front) because the thermometer is sitting in the ambient room temperature and the fan is moving air that is also ambient room temperature towards it.
I would say that cooling would be better acheived by a methanol injection system is you were serious about it.
-Shannon
I meant that the wind IS the air being drawn in. And I do agree that part of the gain of making the scoop is so that there is no vacuum now because it's opened up thus more air. But what I'm saying is. The outside air/wind being drawn in by the scoop is much, much cooler than just the stale air sitting in the fender wall that would be there without a scoop. Going by what your saying... if you were to drive in 30*C and minus 20*C temperatures, both going at the same speed.. the air being drawn into the CAI would be the exact same temperature with the air scoop?
Trevor
Trevor
Trevor
Trevor
The air doesn't cool down because of velocity. The air isn't actually moving at all. But, yes, the location the air drawn form may pull in some air wth a lower ambient temp
-Shannon
this idea has been proposed before...basically routing the intake duct to grab air from the passenger compartment, so when the AC cools that down, the engine feeds from the already cool air. Since the compartment is so large, it isn't going to warm up during the <14 seconds the car is at WOT and the compressor is off.
Trevor
Trevor
Now for your idea of holding your hand out the window and feeling it that it is colder, try this. Put a thermometer in front of a blowing fan in a closed room. Leave it there for however long you want (10 minutes, and hour, whatever). Go back and check the thermometer. It will read the same temperature. Why? When you put your hand in front of the fan, you can feel the cool air? Simple. Regardless of hot or cold, your body is emitting moisture. When you blow air across a surface with moisture, some of the moisture will evaporate, taking heat with it. A fan blowing air across your skin or you sticking your hand out the window of a car results in alot more moisture evaporating and taking heat away than if your skin is just sitting with little or no air flow moving across it. It feels cold to you, because your skin is losing heat. This is the same reason why we sweat when it is hot out. Evaporation steals more energy than almost any other cooling system. It's all about the wonderful world of physics!
I think when he was saying if you stick your hand out the window the air out there is cold. I think he was talking about if it was cold already your not gonna cool down the air that much to see a postive effect by using the air conditioner to cool it down. I'm not sure how it is in Boston where he is at but i'm pretty sure it gets pretty cold out there. He in cali you can stick you hand out the window and the air out there doesn't feel very cold sometimes. Either way to his defence i think what he was saying was misunderstood.
It doesn't matter if your in boston or in cali...It has to deal with the humidity in the air and how saturated it is.If it's very humid then the evaporation rate is decreased and it doesn't feel very cold.If the air is dry then it will feel a good bit cooler regardless of the air temp. Evaporation is a endothermic reaction which means it uses heat to make the change from a liquid to a gas. Thats why if it's humid out..you sweat like a pig!!!Chemistry does wonders!!!
