cold start high idle
Old Oct 28, 2007 | 11:31 PM
Daniel6718's Avatar
cant figure it out...i can drive 5 minutes and it will still ilde at 1500-1800 at lights...but 5 seconds after i start it if i let the clutch out and bog down the motor 3 or 4 times it will idle down to 100 and stay there just fine...
i removed the t/b and cleaned well...check for vac leaks...but its perfectly fine after it idles down, like it has trouble searching for idle...but it doesnt change just stays at 1500-1800...if i let it sit and idle it will take about 45 seconds and it will idle down to 1000
my friends cars the same just an auto and he starts his and it idles great even on cold starts
might be related but when i park my car after driving it kinda smells like gas as i get out, but not when sittin there...think the charcoal canister might be full...can you dry it out or clean it out or do you have to purchase a new one?
Old Nov 2, 2007 | 04:51 AM
Guest47904's Avatar
Guest
Sounds like you're running too rich. Gona have to scan it to see what the O2s are reading and what the fuel trims are. At least look for a ruptured FPR or a leaky injector.
Old Nov 2, 2007 | 07:32 PM
OBE1 95Z28's Avatar
Dab a little oil on the throttle body butterfly rod, where it enters the housing. My rpms stuck after cleaning the TB. Oiled it and the problem went away.
Old Nov 2, 2007 | 08:23 PM
Daniel6718's Avatar
fpr is good and no leaky injectors...on ls1tech they though i had a vacume leak checked it to be 18-20 at idle...
its funny you can watch it learn its idle...from 1500 to 1200 to 1100 to 1000 ans its smoothe all the way until it idles about 950-1000 when it does it starts a random not miss but stumble
Old Nov 3, 2007 | 04:22 PM
splatmatic's Avatar
I know my car had a high idle for a while and couldnt figure it out. I found out that the cruise control cable was just tight enough to keep my idle up around 1800rpm. Disconnected the cable and no more high idle
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
IRABuss
Sep 7, 2011 09:08 PM
