Cold revving -> blue smoke (video inside)
Old Jun 22, 2007 | 05:21 AM
JustNO's Avatar
I know it is not healthy to rev the cold engine, but is that blue smoke related to the cold revving ? Is it normal ?
Blue smoke is at the end of the video. (sorry for bad quality, recorded by phone)
Any opinion will be great
http://www.youtube.com/watch?v=KNb0OF7wESk
Old Jun 22, 2007 | 07:15 AM
transAMdriv3r's Avatar
Im no expert but i just had my engine rebuilt and it does smoke a little bit when its cold, but it goes away pretty quick. I guess cause the rings need to warm up and expand.
Old Jun 22, 2007 | 07:18 AM
JustNO's Avatar
I hope so. Because It's a new engine. (1500 miles or so)
Old Jun 22, 2007 | 09:10 AM
arcticz28the383's Avatar
Do you have any piston slap, and does it smoke when warmed up?
Old Jun 22, 2007 | 10:20 AM
96z28t56's Avatar
its probally just oil gettin past the rings when their cold and havent expanded yet
Old Jun 22, 2007 | 10:57 AM
JustNO's Avatar
No I have not piston slap. Sometimes it smokes when it is warmed up @ WOT
Old Jun 22, 2007 | 10:58 AM
JustNO's Avatar
is this a regular thing? (blue smoke when revving cold engine)
Old Jun 22, 2007 | 11:00 AM
TobyZ28's Avatar
Its not normal to smoke blue smoke ever with the exception of a newly rebuilt engine. Mine did the same thing for a little while after my rebuild Mind you I noticed it on shifts on the highway, i never did rev it when cold...
Old Jun 22, 2007 | 11:18 AM
JustNO's Avatar
I will drive it and I will look if there is any blue smoke at WOT after its warmed up. I don't want to believe that my piston rings didn't seat correct.
Old Jun 22, 2007 | 11:33 AM
Z28SORR's Avatar
Ditto, should never blow blue smoke. Your engine does NOT need to be warm for the "rings to expand", this is nonsense. Your engine should be well broken in at 1500m.
If after rebuild you used synthetic oil your rings may not have seated properly. Or may not have been installed correctly. Worn valve guides and/or seals can also cause blue smoke. Or it could be just your PVC.
Old Jun 22, 2007 | 01:21 PM
SSmoknLT1's Avatar
sounds like valve seals to me
Old Jul 9, 2007 | 08:34 PM
DIYAR21's Avatar
i have never seen blue smoke on cold start from any car.
that was weird!
grabbem88
Mar 18, 2015 01:25 PM
captcorvette
Mar 7, 2015 12:37 PM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
